New DJI RS 3 Pro Firmware Released (6/29/2022)
6706 15 2022-6-28
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2022.06.29
  • Firmware: v01.00.00.00
  • DJI Ronin Image Transmitter (RavenEye) Firmware: v01.03.00.30
  • DJI Ronin Tethered Control Handle Firmware: v32.33
  • DJI Ronin App iOS: v1.5.0
  • DJI Ronin App Android: v1.5.0
  • User Manual: v1.0
What's New?
  • Added ability to access Timelapse, Track and Panorama by sliding left on the touchscreen.
  • Added focus control through the Ronin app with the DJI RS focus motor attached.
  • Added support for multiple subjects selected when using the DJI LiDAR Range Finder (RS).
  • Added auto power off when the gimbal is in sleep mode and idle for more than 10 minutes. The feature is available when sleep mode is entered by pressing the power button.
Notes:­­
  • Motor parameters are reset after updating firmware. Make sure to autotune DJI RS 3 Pro.
  • Make sure that the DJI Ronin app is the latest version when updating the firmware.
  • Update the firmware using the DJI Ronin app by connecting the DJI RS 3 Pro via Bluetooth. Do not disconnect the DJI Ronin app and DJI RS 3 Pro during the update process.
  • Update the firmware for the DJI Ronin Image Transmitter using the DJI Ronin app by connecting the Image Transmitter via Wi-Fi. Do not disconnect the DJI Ronin app and DJI Ronin Image Transmitter during the update process.
  • If DJI RS 3 Pro has a camera attached and is powered on while updating the firmware, make sure to protect the camera and lens as the motors will power off during the update.
  • If the firmware update fails, restart DJI RS 3 Pro and retry.
2022-6-28
Frontliner 2020
Philippines
Thanks for the update and info...
2022-6-28
Montfrooij
Flight distance : 2560453 ft
Thanks for the info!
2022-6-29
Fred Fred Fred
Flight distance : 4512966 ft
Thanks you Dji.
2022-6-29
Pleininger
Running into a bug. I have updated the ronin Rs3 3 pro from my iPhone, but now the ronin app wont connect with the gimbal. Rs3 pro shows up on the Device List, when i tap on the name, it spins for a couple seconds but does nothing. If i refresh the list, it will no longer appear and say “no compatible device”
Please advise, thanks
2022-7-10
djiuser_FJ9gqwhotky3
My RS3 pro is not being found by the app
2022-7-19
fans4b6ce606
I have had two rs3 pro gimbals get stuck at updating the firmware at 80%. I update the gimbal by itself first, then plug on the LiDAR, not firmware updates show up, plug on the focus motor and it says inconsistent firmware, click update and it starts at 80% and never moves on the app. The gimbal says completed with a green check mark but the iOS app keeps at 80%. Same thing with both gimbals, different gimbals and focus motors, same LiDAR. Updated the LiDAR via a computer.
2022-7-28
fans4b6ce606
2022-7-28
Jaygo
# firmware update failed (error code 1003) every time#
2022-7-29
fanse7cef96d
Flight distance : 2859921 ft
Qatar
fans4b6ce606 Posted at 7-28 18:32
same here and found alot of ppl have the same issue , i couldnt do it in dji assistant for ronin,on mac the sotware couldnt see the gimbel
2022-7-29
fanse7cef96d
Qatar
Dji ADMIN please responed
the dji assistant for Ronin cant see the gimbel on mac , i tried all the cabels ,restated computer and gimbel many times ,,,still net seening the gimbel
2022-7-30
MasterTr011
Same here
1 Can't update the firmware to 1.00.00.00.00 from 00.01.00.51. Updating through app says Firmware update failed (-1003) I've restarted but the problem persists. Ronin Assistant app not recognizing USB plugged into RS3 Pro.
2. No video input message on the touch screen but HDMI is installed and double-checked camera settings. (a7siii)
3. Android app crashing Pixel 4. Ipad is working but won't update the firmware...(-1003)
I think DJI is having some issues.
2022-8-13
MasterTr011
MasterTr011 Posted at 8-13 21:08
Same here
DJI has a beta version on Android, use it. Ipad is FUBAR right now.
2022-8-14
djiuser_1HMHU9O1lwJD
Hi I have canon eos 700d, and I just bought the recipe 2 pro pack and the raveneye dosnt work with my camera, will there be an update to be able to use it ? I can’t afford to buy a whole new camera
2022-8-20
Qat1981
Qatar
Hi,
Firmware Update Failed !!
i tried to update through phone app ...??
DJI RONIN RS3 Pro...
2022-9-18
fansc9181dbe
Updated firmware now joystick will only tilt in fpv mode. Can no longer pan or use dial to roll. Even after changing joystick to pan/tilt in app and on ronin.
2022-10-7
