Mini 3 Pro Lens Shade Came Off Camera-Fail!
4368 6 2022-6-29
MacMyDay
Flight distance : 567477 ft
The poorly designed gimbal protector for the Mini 3 Pro appears to have pried off the front bezel of the camera which appears to be a sort of lens shade. See photos.
I'm in touch with DJI support and they will replace the drone, but I'm out of the country and can't replace this as I'm traveling.
I've tried to snap the piece back on, but appears perhaps a clip is missing. This could've been defective from the start.
I'm wondering if until I get back home and ship the drone back to DJI if this will affect flight and/or photography. Obviously, I cannot attach any filters to the camera as a start.
dpi mini 3 fail
dpi mini 3 fail
2022-6-29
Bashy
Flight distance : 2354357 ft
HI, it should twist on to lock in place,
2022-6-29
DJI Stephen
Hello there MacMyDay. I am sorry for the trouble this has caused and thank you for reaching out. It is good to know that you have already contacted our DJI Support Team for further assistance with regards to this matter. Kindly please rest assured that we will do our best to help you and give out the best resolution for the said issue. Again I am sorry and thank you.
2022-6-29
Bigplumbs
Flight distance : 620164 ft
It just twists on and off it is like that for putting on ND filters. There was never any glass in it. You need to be very gentle whe putting the gimbal cover on and off
2022-6-29
Blériot53
Flight distance : 6188465 ft
Try offering it up to the gimbal at a slight angle, then push and twist to lock (very gently)
2022-6-30
bannerman
Your picture shows the camera in portrait mode (vertical).  The MIni 3 manual states that the camera should be placed horizontal when attaching the gimbal cover.   This has probably caused the problem.
2023-12-20
Rej
Flight distance : 279692 ft
Here is video demo of proper installation starting at 5 minutes.
2023-12-21
