360 Photosphere - Top image is blurry
2181 9 2022-6-30
piratefache
Flight distance : 699229 ft
Switzerland
Hello I bought this drone about a month ago, when I received it I updated it (v01.00.0100) and everything went fine with the drone.
But I noticed that the top of the image (about 30% of the image) is totally blurry.
It looks like the drone doesn't take enough pictures and just fill the image with some blurry pixels...
Anybody got this problem too?
raw files (not blurred)
2022-6-30
Yazu
Flight distance : 2351857 ft
Finland
This is normal, the drone doesn't take pictures where the image is blurry.
2022-6-30
piratefache
Switzerland
Yazu Posted at 6-30 00:48
Personally, when I read "sphere" I presume it's 360 degrees... especially when the camera tilt is up to 60°.
2022-6-30
Yazu
Finland
piratefache Posted at 6-30 00:54
I feel they just copied the sphere photo  code off from the Mini2, as it had similar blurry top when taking 360 photos. Hopefully this will be fixed in upcoming firmware updates
2022-6-30
piratefache
Switzerland
I'm disappointed. I did not expect misleading information from DJI.
I found an article (in french) about how to manually complete the sphere by adding some extra shots : https://www.helicomicro.com/2022 ... raies-photos-a-360/
2022-6-30
DJI Susan
Hi there, this is normal when doing a 360 sphere pano shot. Our engineers will optimize this, and hopefully, the firmware will be released soon.
2022-6-30
DowntownRDB
Flight distance : 1722 ft
That is normal.  Hopefully, a firmware update is being worked on and that gets fixed.
2022-6-30
Blériot53
Flight distance : 6188465 ft
It's less than satisfactory, isn't it. And it's a bit of a faff to improve it manually in an editing program.
2022-6-30
GTS 350
Piratefache
"I did not expect misleadiing information from dji."
Thats funny. It seems that's the only type of information dji gives out.
2022-6-30
Montfrooij
Flight distance : 2560453 ft
It works like that. Once you view it in a 360 viewer, it is looking much less weird.
The camera can't capture what's above the drone due to the props and body that are in the way.
But again, upload it to a 360 viewer and you will see it works just fine. It's just a small area above (that does not hold anything interesting).
And if you really don't like it, you can always stretch the top part (sky) before uploading. That's what I usually do.
https://www.tricks-and-tips.nl/p ... with-a-dji-panorama
2022-6-30
