RC update
452 7 2022-6-30
djiuser_wgupliCky4m6
Flight distance : 234111 ft
Hi can i update fly app on new RC without connecting to a drone ?
2022-6-30
DAFlys
Yes you can,  go to camera view and the three dots,  about and tap check firmware and it will trigger the RC update.
2022-6-30
DAFlys Posted at 6-30 22:49
Thanks for reply , check for updates greyed out .my drone has broken and on way to dji so cant connect it.
2022-6-30
DowntownRDB
Flight distance : 1722 ft
How about using DJI Assistant 2 to update the RC.
2022-7-1
DowntownRDB Posted at 7-1 03:42
How do you this ? Never used assistant
2022-7-1
DowntownRDB
djiuser_wgupliCky4m6 Posted at 7-1 04:00
You can download the DJI Assistant 2 (Consumer Drone Series) here.
It's not hard to use.  Just download and install on your PC.  Open the Assistant 2 and log in using your DJI Account info.  Then start your RC.  Connect a cable between PC and RC and then the Assistant 2 will recognize the RC and you follow the prompts from there.
Here is a DJI on how to use the Assistant 2 if you need it.  It covers the Mavic 2 but the process is almost the same.
Hope this helps.
2022-7-1
DAFlys
djiuser_wgupliCky4m6 Posted at 6-30 23:43
Did you make sure the wifi is on?    I always update the controller before doing the drone.
2022-7-2
Hi , got it sorted thanks for all the replies
2022-7-2
