Magic air 2s
317 3 2022-6-30
Penguin5163
Can anyone help with this. I've had my drone for about a year and I crashed it in some tall grass and now it will not fly sideways. It will turn on its access it will fly forward and back and up and down but will not fly sideways. Any ideas?
2022-6-30
DJI Susan
Hi Penguin5163, could you please check if you have enabled the function called "disable sideways flight"? If yes, you may try to disable this option to be able to perform sideway fly while using N mode. It is under Safety settings. Noticed that you had crashed the drone into the grass, please check the drone thoroughly and see if the drone got damaged.
We may also suggest that you send the drone back to us for comprehensive checking. You can click https://www.dji.com/us/service/repair to start an online repair case.
2022-6-30
Penguin5163
I had to reenable sideways flight thank you so much for your help.
2022-6-30
DJI Wanda
Penguin5163 Posted at 6-30 19:39
You are most welcome. Please let us know if you have any questions.
2022-7-1
