Mini 3 pro (Code: 180059)
27960 19 2022-7-9
Skyd34th.com
Flight distance : 652831 ft
Poland
Mini 3 pro: Aircraft not in flight. Vision systems and obstacle avoidance disabled (Code: 180059) how to live further?  what to do?
2022-7-9
DJI Wanda
Hello, there. The aircraft will disable vision sensors when it is on the ground to reduce power consumption. When the aircraft takes off, all vision sensors will be enabled. Please feel free to use them.
2022-7-10
djiuser_7erTXivkGEnJ
Flight distance : 16316 ft
Poland
DJI Wanda Posted at 7-10 02:02
Nie prawda, mam ten komunikat na stałe. Nie ma znaczenia czy dron wpowietrzu czy na ziemi, nie działa rownież lot bokiem. Oddaje drona.
2022-8-15
DJI Wanda
djiuser_7erTXivkGEnJ Posted at 8-15 02:48
Hello, there. Sorry for your inconvenience. If these error messages appear in whichever scenario, you can contact our support or apply for a repair request and then send it back for further diagnosis.
2022-8-15
djiuser_Beg4HSZ6jnQp
India
dji mini 3  error 180059, I have the same issue after upgrading the new firmware. Initial issue was unable to fly. I got a firmware directly from dji, after upgrading unable to fly issue is resolved but another problem came. And another problem is automatic object tracking is disabled. Not able to enable it
2022-10-25
India
djiuser_Beg4HSZ6jnQp Posted at 10-25 06:55
dji mini 3  error 180059, I have the same issue after upgrading the new firmware. Initial issue was unable to fly. I got a firmware directly from dji, after upgrading unable to fly issue is resolved but another problem came[Image]
2022-10-25
djiuser_TuIuoCX8n7IH
dji mini 3  error 180059, I have the same issue after upgrading the new firmware. Initial issue was unable to fly. I got a firmware directly from dji, after upgrading unable to fly issue is resolved but another problem came. And another problem is automatic object tracking is disabled. Not able to enable it[Image]
Me to - flight check says unable to take off and I get the 180059 error right after updating firmware today. Keep me posted pls
2022-10-27
djiuser_6maB8fWSyctx
Flight distance : 28438 ft
Hi, same issue. Since the latest firmware update the Mavic 3 will not take off. Prop motors will not initiate with sticks or auto take off. Error code 180059 appears in the flight checklist. I've reconnected the RC to the drone, but no luck. Dead in the water here. Is there a solution yet?
2022-11-4
AMDay
Same here. This is ridiculous! I pay over $1000 for equipment and I can't fly it for more than 2 weeks now due to update error! COME ON! This is the error I get.
Aircraft not in flight. Vision systems and obstacle avoidance disabled(Code: 180059)
2022-11-5
djiuser_V0Jisb7NMTkr
United Arab Emirates
Same here ((
2022-11-5
Skyd34th.com
Poland
AMDay Posted at 11-5 07:48
it's not a bug, you can fly. it is just unnecessary information that obstacle avoidance is disabled when you are not flying to save energy.
2022-11-7
DJI Tony
Hello there, DJI Forum users. Thank you for your inquiries. Skyd34th.com is correct. Please be advised that (Code:180059) is not an error code but simply a prompt. This means that the aircraft will disable vision sensors when it is on the ground to reduce power consumption. When the aircraft takes off, all vision sensors will be enabled. Please feel free to use your drones. However, if you are unable to take off after the update, you may try to do a "Firmware Refresh" through the DJI Assistant 2 (Consumer Drones Series). Should you have any concerns or inquiries, please do not hesitate to reach us here at DJI Forum. Thank you for your continued support.
2022-11-7
Melwyn
Flight distance : 274029 ft
India
Can someone help me with this error. I cannot fly my drone
2022-12-15
DJI Wanda
Melwyn Posted at 12-15 09:06
Hello, there. Sorry for the late response. We would recommend you restart the device and see whether those error messages will disappear. If not, please contact your dealer for repair or replacement.
https://repair.dji.com/repair/index
2022-12-15
Bigplumbs
Flight distance : 620164 ft
How did you perform the update...... Did you use a PC ?
2022-12-16
djiuser_SoiZ9AkELqbz
Aircraft won't take off. Receive the mini 3 pro yesterday and unable to fly. Tried the firmware refresh using Dji assistant. What is the solution for this? Its a brand new drone unable to fly
2022-12-21
djiuser_HoBx0GTxygSz
Same issue with my mini 3 pro. Was anyone able to fix this? Haven't been able to use my drone since the last firmware update. Only flown this thing once and unable to use for the past 2 shoots. Very frustrating!
2023-3-25
DJI Tony
djiuser_HoBx0GTxygSz Posted at 3-25 08:20
Hi there. Thanks for reaching out, and apologies for the inconvenience. To confirm, are you getting error code 180059 and unable to take off as well? If yes, kindly refresh the firmware of the drone using the DJI Assistant 2 (Consumer Drones Series), and try again. Please keep us posted. Thank you.
2023-3-26
djiuser_YMqP197K9A63
Cyprus
hi i have the dji3 pro and i did the new version and it gives me a problem on the screen when i turn on the drones
2023-4-18
supergeo.ca
Flight distance : 263537 ft
djiuser_YMqP197K9A63 Posted at 4-18 07:37
hi i have the dji3 pro and i did the new version and it gives me a problem on the screen when i turn on the drones[Image]
Try setting camera to auto mode, as it looks like you are overexposed.
2023-4-18
