Installed white led light today
PerlanSwed
Flight distance : 1456847 ft
Sweden
Modded my P3P today with a white led light. And this without to have open or do any thing to the P3.
What do you think?
P3P with led light
P3P with led light
2015-8-4
phinchman
Flight distance : 120994 ft
Puerto Rico
Hi, what was the procedure you used?
2015-8-4
PerlanSwed
Sweden
Do you mean how I installed it or the product i used?
2015-8-4
Trilithon
PerlanSwed Posted at 2015-8-5 01:21
Yes...
2015-8-4
dji.blitzk
Flight distance : 1752986 ft
Which switch do you use to turn it off/on in the air?
2015-8-4
Rigworker
Flight distance : 52303 ft
Some details please.
Where did you get the led light? How did you attach the light?
How do you supply power to the light?
Any glare in the camera from the light?
2015-8-4
calibergsd
Why? What is the purpose of this?
2015-8-4
phantom3menace
calibergsd@gmai Posted at 2015-8-5 04:48
I wanna know as well. (maybe to drain the battery quicker for shorter flight times?) lol
2015-8-4
acenothing
Flight distance : 112185 ft
Me too, what it the use for this?
2015-8-4
aburkefl
Flight distance : 78612 ft
acenothing Posted at 2015-8-5 07:11
It seems logical that it would assist identifying orientation. Personally, if I did this, I would put that bright light on the back, make it switchable and keep it away from anywhere near the camera.
2015-8-5
msjh
Lots of questions.  It would be interesting to know the answers.
Apart from anything else, the LED would help with visibility.
2015-8-6
PerlanSwed
Sweden
Rigworker Posted at 2015-8-5 04:40
How do you supp ...
Sorry for delay in answer, but vacation is ended.
So far no glare in the cam.
Attached by velcro.
Power from main battery via a very thin adapter. I will provide a photo so you see.
Battery time seem them same +/- 1 minute
Will give link to producer when im sure that it is a nice product so I can recommend.
You can find it if you google anyway.
2015-8-6
PerlanSwed
Sweden
msjh Posted at 2015-8-6 16:06
Apart from anything else, the LED  ...
Sorry for delay of answer, but vacation is ended.
See post with photos
2015-8-6
Vampiszon
Belgium
aburkefl@gmail. Posted at 2015-8-5 20:44
It seems logical that it would assist identifying orientation. Personally, if I did this, I would  ...
What's the difference if it's back or front or side when you have everything on screen in front of you and you know what direction is P3 pointed on the minimap.
I realy don't understand any lights on P3
2015-8-6
aburkefl
Vampiszon Posted at 2015-8-6 19:58
What's the difference if it's back or front or side when you have everything on screen in front of ...
You're flying along, fat, dumb and happy (just an expression!) and suddenly discover your Pilot app has frozen/died. You look up at your Phantom and it's just a dot in the sky. Maybe it's a little bit closer, but much too far away to tell very much about it.
If it's not too far away, you can steer left or right and see what happens to your Phantom, if you can tell. At what point do you finally decide it's really serious and you can't tell whether your Phantom is facing away, toward you, off to the right/left, etc? GPS lock gone?
You can't even manually fly your Phantom if you can't tell its orientation. But, if you could see a bright white LED and know that must the back of your Phantom, you can pull back on the stick safely, knowing it's going to fly back in your general direction.
Many, many, many users want to fly their Phantoms further and further. After your Phantom gets more than a few hundred feet away from you, it becomes extremely difficult to identify its orientation. Even if you do still have a video feed, the latency may be just enough to not show you just how close you are to an obstacle. Now if your Phantom could be lit up like Christmas!
2015-8-6
PerlanSwed
Sweden
Its for the General Aviation in G-airspace that not follow the height rules to flying on min 300ft height in open terrain and 500ft over ground when their is buildings.
I want them to see my quadcopter!
In Sweden you are allowed to fly up to a height of 360ft (120m) with a QuadCopter UAS1A.
And I also sometimes have permit to fly in CTR- area.
I will also install some small mini led-flash, so my P3P will be a almost like a christmas tree and no one can miss that its up in the air.
2015-8-6
PerlanSwed
Sweden
aburkefl@gmail. Posted at 2015-8-6 20:07
You're flying along, fat, dumb and happy (just an expression!) and suddenly discover your Pilot ap ...
Can already verify the use of strong head light from last evening when I need to recover back. But for my personal use I install extra light for others to see the Quad.
2015-8-6
aburkefl
PerlanSwed Posted at 2015-8-6 20:20
Can already verify the use of strong head light from last evening when I need to recover back. But ...
Nothing wrong with that either.
As noted elsewhere, I have a Phantom 3, a Chroma and pieces of what used to be a Blade 350. The LED array on the Chroma is HUGE! Once that thing gets well up into the air, it is VERY visible.
2015-8-6
jimcloud74
Flight distance : 1298317 ft
Seems logical to me. I would like to see something that operates like this for safety. Lets face it, we need all of the good "safety" publicity we can get. We have to shut the naysayers down when it comes to the dangers of drones in airspace. I would love to see a mapable toggle for on off on the bottom of the controller. I also wish that the red was rear and the green was front. I have been flying these for years and still have "crossed wires" in my head sometimes. In America and most everywhere else, brake lights are red.
2015-8-6
Rigworker
Handy if you are at limits of LOS and the app dies or glare is bad.
2015-8-6
rayrokni
Flight distance : 8139875 ft
take a pair of binoculars. you can velcro that to forehead for hands free operation if u like.lmao. sorry had to get it out of my system. if itis that far from u i doubt u ll see the led. best is a pair of binoulard, imo.
thx
2015-8-6
rayrokni
jimcloud74@yaho Posted at 2015-8-6 23:10
Seems logical to me. I would like to see something that operates like this for safety. Lets face it, ...
just swap the lights around, takes a few hours
2015-8-6
aburkefl
rayrokni Posted at 2015-8-7 14:40
take a pair of binoculars. you can velcro that to forehead for hands free operation if u like.lmao ...
This issue is obviously where a lot of the guys and I part ways. I don't see the necessity of flying my Phantom (or any other quad) miles away from where I'm standing. Many will complain that the (fill in the blank) is only good for about 800 yards. That's fine for me. Thus far, the photographic sites I've videoed are well within such a range.
Overall, I'm not happy with being forced to utilize another, separate device to run the Pilot app (or the GO app that still doesn't work on an Android). That's one of the reasons I've really been enjoying my Chroma.
In total fairness, the camera on my P3 - well maybe not so much the camera as the controlling of it - is far, far superior to just about anything else I've seen out there. I've owned five (5) quads so far and the Phantom 3 is the best photography platform I've seen.
2015-8-7
rayrokni
aburkefl@gmail. Posted at 2015-8-7 19:38
This issue is obviously where a lot of the guys and I part ways. I don't see the necessity of flyi ...
So that's a no to Velcro idea then?
2015-8-7
KP P3 Adv
Flight distance : 35650 ft
Does anyone have any info about when the DJI Pro app will be available for Android?
2015-8-7
Albert Jr.
Flight distance : 2422041 ft
rayrokni Posted at 2015-8-7 23:35
lol
I like you Ray... you look like a fighter.... or a Sumo!
Albert
2015-8-7
rayrokni
Albert Jr. Posted at 2015-8-8 09:38
lol
gotta have fun albert, without disrespecting anyone though.  my aim at this forum is to helpm as much as i can, learn from others and if i find friends then it was time well spent. as far as fighter, lets just say i will now days walk away and then smash my p3 into a tree instead. as far as sumo, are u calling me fat?
be safe and enjoy life, 100 years from now nobody is gonna give a shit!!
2015-8-9
rayrokni
phinchman Posted at 2015-8-5 01:10
i thought u said we didnt have to open or do anyting to p3? cuz im either confused or the pix are showing wires going in the grills and coming out of the othe side, also wires going in to battery terminals??
thx
2015-8-9
Albert Jr.
rayrokni Posted at 2015-8-10 13:38
gotta have fun albert, without disrespecting anyone though.  my aim at this forum is to helpm as m ...
Sounds good Ray!
No... not fat.... "thick"  like you could take a hit
NO disrespect intended.
Albert
2015-8-11
Bob Bauer
I can not figure out how the positive and negative terminals attach in the photo above.  Can you clarify this please. I have the lights but it makes no sense to me on how the tabs attach.
2015-9-10
greenbean
Flight distance : 84783 ft
Bob Bauer Posted at 2015-9-10 15:06
I can not figure out how the positive and negative terminals attach in the photo above.  Can you cla ...
This should help you. Since he had stated he did not take the bird apart I can only guess he un-soldered the board and snaked them (with much patients) through the grill….or perhaps easier would be to go through the grill first then pull the wires through.
http://www.amazon.com/SKYREAT-Ph ... s=phantom+led+light
2015-9-10
greenbean
rayrokni Posted at 2015-8-10 01:45
i thought u said we didnt have to open or do anyting to p3? cuz im either confused or the pix are  ...
This is just one place to purchase, but found it had the best pictures…(see my previous post to Bob Bauer)
2015-9-10
Sling Shot
PerlanSwed Posted at 2015-8-6 04:16
Is there a switch on the side?
2015-9-10
PerlanSwed
Sweden
greenbean Posted at 2015-9-11 03:19
This should help you. Since he had stated he did not take the bird apart I can only guess he un-so ...
Yes, thru the grill. You do not need to do any soldiering.
2015-9-11
PerlanSwed
Sweden
Bob Bauer Posted at 2015-9-10 21:06
You can see in your AC that red positive is the upper stift.
2015-9-11
PerlanSwed
Sweden
Sling Shot Posted at 2015-9-11 07:21
yes, the switch is on the small board you have on the side.
2015-9-11
greenbean
PerlanSwed Posted at 2015-9-11 11:50
what would be really cool is,   if it could be wired to the front ESC's board so it could be turn on/off by the app
2015-9-11
