THE PRISONER
Flight distance : 890338 ft
alangill@outlook.com Posted at 8-16 08:15
I've got exactly the same problem and this is a replacement drone, the first one wouldn't do a firmware update and failed at 89%, the new one arrived last week and updated perfectly but noticed the red icons when flying...it does however beep when landing and also alerts if I fly it too close to myself both frontwards or backwards, though haven't been brave enough to see if it will fly around an obstacle...im guessing this is a bug that needs a fix...
as you can see on the video, mine does not bleep or warn me at all when it turns itself off it just goes red and acts as if i have turned it off ? (it stll says its on, when looking at my controler) and in a blink of an eye it will become white, as if i had turned it back on and will bleep as normal, but then will randomly turn to red again, with no warning at all. there is no way of turning it off from within the fly app and then back on, nothing works apart from having to RTH and shutting the drone off and then back on |
