WaterMaster
MeAtHome Posted at 7-11 22:05
The Mini 2 and the Mavic 2 run on different modes. When switching between the two aircraft, the smart controller “boots” between these modes.
Mini 2 -> M2P
When I turn the SC on I get the start-up screen and with no aircraft active a Connect box in the bottom left with a constantly changing background image. Had I powered up the last aircraft I had flown BEFORE powering up the SC, the SC would have shown the name of the aircraft and instead of Connect the text would have been Go. If I power up the aircraft AFTER the SC it will connect to the SC and the Connect text will change to Go. Pressing Go launches what ever app is associated with the active aircraft, DJI GO 4, DJI FLY, or DJI Pilot.
By looking at Settings/Aircraft Management I can find what the 'Default' aircraft currently is, the image to the far left. Your 'work-around of "ADD/Cancel/Select" saves the wasted time of re-linking the MM2, again and again and again etc...
In my day we would have a 'planning' meeting where everyone decided the 'flow' of a process:
Power on
Active screen showing active aircraft or no active aircraft until one was powered on
Button to launch what ever app to fly the active aircraft
That the process can not detect and 'switch' to what ever the active aircraft is would be a show stopper.
That the company would allow this and NOT bother to document it is sad, the man hours wasted and frustration caused does no one a favor. At one point in this process I was getting ready to send my MM2 in for warranty repair, the sad thing is they would have probably taken it. |
