Mavic 3 Battery explodes on impact
1806 13 2022-7-12
Suren
Flight distance : 13498560 ft
New Zealand
Does not look good. At least Dji took responsibility and replaced the drone - Well done Dji
2022-7-12
fateofangel
Flight distance : 1397238 ft
Poland
so it is a Maneuver Ammunition
2022-7-12
TonyPHX
Flight distance : 11229610 ft
To be fair, those batteries hold a lot of stored potential.  A crash could certainly result in a fire.
2022-7-12
CloudVisual
Flight distance : 97545420 ft
TonyPHX Posted at 7-12 12:39
Couldn't agree more. I'm surprised they don't catch on fire more to be honest.
People don't realise just how much energy is stored in these and how fragile they are.
2022-7-12
DAFlys
Ouch.   thats not good.
2022-7-12
bjr981s
Flight distance : 139698 ft
Not unusual for a LiPo. Have seen many Ducted Fan jets explode on impact.
2022-7-13
Monkey007
Flight distance : 73775046 ft
bjr981s Posted at 7-13 00:08
The Mavic3 packs are pretty much the size of a 450 class heli 4s pack, these guys will freak out when they see a 700 class heli 12s lipo explode...LOLLL
2022-7-13
DowntownRDB
Flight distance : 1722 ft
Wow, that's not good.  Glad that DJI replaced the drone.
2022-7-13
TonyPHX
Even a small thin ipad, when the battery goes it is quite destructive.
2022-7-13
Lucas626
Flight distance : 50642090 ft
Those batteries are little explosives if not given the right care.  I can see how they could explode or create a short circuit on impact.  I charge my RC LIPO batteries inside an ammo box that I that I drilled holes for wires to go through.
2022-7-13
bjr981s
Monkey007 Posted at 7-13 01:13
You are right about that. I have many 12S battery trays set up for my Align 700 and 800 helis.
Too hard to charge at the club so have about 5 trays per heli. I hope nobody runs into my rear when carrying them in the car.
2022-7-14
The Saint
Flight distance : 5902228 ft
strange that the video doesn't mention anything significant about the fire, when it started, how long it lasted, how big was it, did he come upon the burning wreckage, or anything about the battery....unless i missed it.
however, the video says one thing:  installing an aftermarket accessory on your drone doesn't necessarily or automatically void the warranty.
2022-7-17
fans1ea76b90
DJI 4 mini also blow up on air today also
3-16 20:45
DJI Tony
fans1ea76b90 Posted at 3-16 20:45
Hello there. Sorry about the trouble. It's possible that batteries may be damaged if they come into contact with liquids or are exposed to rain or moisture. If water enters the battery, it can cause corrosion, which may cause the battery to catch fire or even explode. The battery should be kept at a temperature between -10℃ and 40℃. If it's used in an environment that's hotter than 50℃, it may catch fire or explode. Using it in temperatures below -10℃ can lead to permanent damage. Also, do not disassemble or puncture the battery in any way, as it can cause leakage, fire, or explosion. We suggest sending the aircraft back to DJI for diagnosis. You can submit a repair request here (https://www.dji.com/global/support). Thank you for your patience.
3-16 21:14
