Prop screws are too tight, I cant take them out for replacement
16036 26 2022-7-13
mkdp.photos
Flight distance : 717218 ft
Recently I noticed one of my prop sets was a little damaged so in order to swap them out I got the DJI screw driver out and attempted to replace them
But the screw on them is too tight and if I try anymore I feel like it will strip
Any tips?
2022-7-13
Bashy
Flight distance : 2354357 ft
Se this thread for a better screwdriver
https://forum.dji.com/forum.php? ... id%3D776&page=2
2022-7-13
mkdp.photos
Bashy Posted at 7-13 18:29
https://forum.dji.com/forum.php?mod=viewthread&tid=269099&extra=page%3D1%26filter%3Dtypeid%26typeid%3D776&page=2
Any options in Canada? The shipping and duties on that will cost more than the screwdriver itself lol
2022-7-13
tanasit
Flight distance : 145509 ft
This is what I will do.
Heat the VERY tip of the screw driver with a lighter (not the torch) for a few seconds then insert the tip into the screw head fully.
Wait about 10 seconds and start to unscrew BUT not forcefully. If no movement at all, reoeat the heating one more time.
The heat from the tip should soften the blue glue at the end of the screw.
Just don’t overheat the tip of the screw driver or the shaft will melt the plastic handle!
In general for bigger screw, I’d use Dremel with cutting disc and cut a slot on the screw head and use the straight tip screw driver for more leverage.
The cheap all metal small screw set will wotk better for above method.
2022-7-13
mkdp.photos
tanasit Posted at 7-13 18:47
This is so annoying
I hate small screws they're always such a giant pain in the ass
2022-7-13
Bashy
I believe any decent PH000 should do the job, the melting of the Loctite is a good idea though, never tried that before so, i mean any other application, so i will remember for future reference
2022-7-13
Bigplumbs
Flight distance : 620164 ft
All good advice
2022-7-13
tanasit
Upon closer inspection, you can see that the stock screw driver tip is just a little too big when compared to the Wera PH 000.
2022-7-13
tanasit
If the screw driver failed, I’d use a small Dremel grinder tip to cut off the prop hub as shown.
You may cut into the screw but it’s ok since you will use a pliers to remove it once the prop hub broke off anyway.
If no Dremel tool, the Exacto blade may work but has to be careful!
2022-7-13
hallmark007
Flight distance : 12400594 ft
Just put some WD 40 on it give it a chance to penetrate and try again.
2022-7-13
DowntownRDB
Flight distance : ****
I use a PH000 out of my wowstick kit as DJI failed to include a screwdriver in my purchase.  Seems the loctite on the tip of the screw is doing its job as expected. Just use steady pressure and it should finally give way.
2022-7-14
VivaLaGucci Music
Malaysia
If your screw is severely stripped like mine, my last resort was melting the propeller plastic around the screw head using a solder and use a pliers to grip the screw head and twist it, works well for me.
2022-7-14
VivaLaGucci Music
Malaysia
VivaLaGucci Music Posted at 7-14 04:03
2022-7-14
Bashy
I got my Wera PH000 today and tried it on the Mini 2 and it works great, still needs decent pressure but no slippage at all...
2022-7-14
Bob-Mini-2
Flight distance : 73114 ft
mkdp.photos Posted at 7-13 18:57
This is so annoying
AGREED! ! !     I got an extra screwdriver from "eslinger.com" they carry watchmaker tools.  For Mini2 it is Phillips 2.00MM
2022-7-14
Bashy
Just found out that the Wera is not magnetic
2022-7-15
MavicMike1955
Flight distance : 933747 ft
WHY, OH WHY, did DJI stray away from the quick release props?  They were SO easy to replace!!
2022-7-15
fans684baa3e
Rub the tip of the Wera against a magnet will do. Or if you have a tiny magnet, just attach it to the shaft as seen.
2022-7-15
The Saint
Flight distance : 6260171 ft
MavicMike1955 Posted at 7-15 06:33
the drone's weight, the overall design, and the cost do not permit and is not particular conducive to these tiny drones (including the autel nano) to use the quick release props.  my personal opinion is it's totally unnecessary and would be akin to quick release tires on your car.  i'm going to give dji and autel the nod that they are smarter than us and they know exactly the good reasons for this.  and btw, in....before the patent infringement people derail the thread.
2022-7-15
Bashy
fans684baa3e Posted at 7-15 11:46
Thanks, i have to .5cm earth magnets which will do the job, i did actually think of that and will do it next time i use it, when i noticed it was only for the accessory panel on my laptop, 1 screw, this time, thanks again for the tip though.
2022-7-15
Bigplumbs
Very poor of DJI messing this up. It is not like this drone is a cheap kids toy now is it
2022-7-15
klaatu barada
The correct size screwdriver is a PH0, as verified by dji
2023-8-20
gopher1
Flight distance : 293898 ft
hi all i come from the servicing game it is  blue lock on screws thats wat it hard to get them out try a soldering iron tip on the head for 1/2  to seconds BUT to long may wreck the motor
2023-8-22
eruby
Flight distance : 11831 ft
klaatu barada Posted at 8-20 11:22
I also got confirmation from DJI Support that PH0 is correct. I purchased a nice set off Amazon with PH0, PH00, and PH000. The PH0 did work the best for me but I must agree with other posts that the included driver has a shorter, blunter tip.
2023-8-22
Bashy
eruby Posted at 8-22 10:53
There are different sizes of PH0, e.g. 40mm, 60mm etc, which did you get?
2023-8-22
eruby
Bashy Posted at 8-22 18:23
Wow I didn't  know there were different sizes of PH0. I got this set on Amazon on sale for $7.99. Worked great but didn't come with a case.
https://a.co/d/2bwjy2z
2023-8-23
Bashy
eruby Posted at 8-23 16:38
To be fair, im not sure what the the size diff means, i only know that i bought a PH000 as advised on here, this was in the early days of the Mini 3 Pro, so i am trying to find the exact size needed as the PH000 doesnt appear that tight in the head, not had to use it mind but just want to make sure its right...
...heres the Wera in the 2 sizes
https://www.amazon.co.uk/Wera-05 ... s%2C65&sr=8-16&th=1
https://www.amazon.co.uk/Wera-Kr ... r%2Caps%2C65&sr=8-5
2023-8-23
