MM_fly
Flight distance : 498399 ft
DJI Stephen Posted at 7-17 20:20
Hello there MM_fly. I am sorry for the trouble this has caused and thank you for reaching out. May we please know what is the model of the mobile device that you are using please and can you please fly your DJI Mavic Mini to a different location with less interference to see if the issue will still persist? The DJI drone might have picked up magnetic interference on the ground, and you took off from close to a buildings with rebar concrete metal objects on it. Kindly Please make sure that the antennas are pointed toward the aircraft for optimal transmission. In addition, the advantages of the DJI Mini 2's OcuSync 2.0 compared to Wi_Fi is that OcuSync 2.0 supports both 2.4 GHz and 5.8 GHz frequency bands. It features stronger interference resistance due to automatic frequency switching, delivering video transmission feeds at up to 10 km ( when unobstructed, free of interference, and FCC-compliant ). Thank you.
[view_image]
Hi
It’s with iPhone 13, all updates on iPhone and apps as of today.
I always use my controller and antennas as you’ve shown.
It’s ok in other places, but just doesn’t go very far, and get interference a lot.
So is Mini 1 only using 1 band and not switching channels, whereas the mini 2 can use both channels and switch on the fly when it thinks it needs to? But it still uses the same WiFi?
Thanks |
