Has the fogging of the lens been solved?
12Next >
7944 41 2022-7-19
Oleg13
Russia
Hi, there! Has the problem with fogging the lens on the Mini 3 Pro been solved? If so, from which batch (which month number) can I already buy a drone?
And has the problem with lens defocus been solved in the new batches?
2022-7-19
DAFlys
Ive flown over 1030km with the mini3 and never had any issue,  its probably climate related.
2022-7-20
Oleg13
Russia
DAFlys Posted at 7-20 01:03
Yes, perhaps because of the climate. I flew in the city and there were no problems. And in the mountains at an altitude of 2500m, it began to fog up.
I read that DJI was recalled from the sale of a batch of drones released before May. I have April. And what month is your batch?
2022-7-20
DAFlys
Oleg13 Posted at 7-20 01:12
I got mine on launch day so I assume its the original batch.
2022-7-20
Oleg13
Russia
DAFlys Posted at 7-20 01:14
I'm waiting for an answer, suddenly dji solved the problem of fogging so as not to depend on climatic conditions. after all, if you go on a trip with this problem with a climate where it will fog up, then the shooting will not work.
2022-7-20
fans6b6353ff
Flight distance : 2388 ft
Austria
can you find out the production date by the serial number?? and if how??already found should obviously be on the packaging under UPC
2022-7-20
Oleg13
Russia
fans6b6353ff Posted at 7-20 02:05
Where the serial number is indicated in the lower right corner is the year and month. In my case it is 2022/4
2022-7-20
fans6b6353ff
Austria
thank you i found it
2022-7-20
tvarad
I concur. I bought mine out from a warm room to the cold outside where it had rained recently and a moisture dot formed inside the lens enclosure within a few minutes.
2022-7-20
Oleg13
Russia
tvarad Posted at 7-20 06:37
And what batch of drone do you have? What month?
2022-7-20
Oleg13
Russia
By the way! And what about winter!? Won't it fog up in winter?
2022-7-20
hallmark007
Flight distance : 9827923 ft
Fogging on the inside of the lens is not a FW or SW problem and it won’t miraculously disappear. If you are having this problem then you have a defective problem and it will occur again and again. You need to return your drone for another.
Many cameras coming from cold into heat fog the lens but not on the inside of the lens like was happening with some mini 3 drones.
2022-7-20
Oleg13
Russia
hallmark007 Posted at 7-20 08:43
Yes, I have exactly this problem and some people have it the same way. That is, this problem is not on all mini 3 drones?
In some parties there is no such problem? What does it depend on?
How do I find out when buying a drone if it has this problem? After all, it can be detected only in certain weather and temperature conditions.
2022-7-20
hallmark007
Oleg13 Posted at 7-20 08:49
You warranty will cover this defect, so if it has shown up you should simply start a return and ask that they repair or replace your drone. Its hard to know when buying but as soon as you see it happening then its time to return.
2022-7-20
Bashy
Flight distance : 2354357 ft
I have a June 2022 Mini 3 Pro and i have not seen this issue yet
2022-7-20
Oleg13
Russia
hallmark007 Posted at 7-20 08:53
Unfortunately, the warranty does not apply in my country(
2022-7-21
Oleg13
Russia
Bashy Posted at 7-20 13:40
Perhaps you have not yet encountered this problem, have not been in such weather and temperature conditions.
Flying in the city, I didn't have this effect either. But flying in the mountains and getting into a cloud, the lens immediately began to fog up.
2022-7-21
Bashy
Oleg13 Posted at 7-21 00:18
Yeah, that probably would cause any lens to fog up, but on the outside.
I heard folks had the issue on warm sunny days, just general everyday day, that's what its been like here, out of my AC cooled car and into 35
ºC temp
2022-7-21
Oleg13
Russia
Bashy Posted at 7-21 00:21
I started at +35 degrees Celsius and there was no such effect. And in the mountains it's cool at altitude. But the lens misted up not at the lens itself, but at the front removable glass - a condensation stain appeared. First I went lower and the fogging went away. But then the cloud flew more and only after landing I saw this spot and the fogging went away. I'm worried that this will happen in winter.
2022-7-21
Bashy
Oleg13 Posted at 7-21 00:24
Probably will, yours sounds like normal condensation from hot to cold, but if it is on the inside of the lens where you cannot wipe it off then you need to get in touch with support.
2022-7-21
Oleg13
Russia
Bashy Posted at 7-21 00:26
The whole problem is that there is no warranty in my country(
2022-7-21
Dryvise
Flight distance : 10869498 ft
Russia
I have no problems, but I heard that the problem is in an incorrectly installed rubber ring: https://www.bilibili.com/video/BV1Pv4y1w7ai/?spm_id_from=autoNext
You can fix it yourself.
2022-7-21
Bashy
Oleg13 Posted at 7-21 00:27
Oh, i see, yeah that would be a problem, send back to china for warranty repairs?...
2022-7-21
Oleg13
Russia
Dryvise Posted at 7-21 00:49
Thanks, I'll check it myself! And you have a drone from which batch?
2022-7-21
Oleg13
Russia
Bashy Posted at 7-21 00:59
Yes, I buy it on Aliexpress, but returning to China is not very easy and I have no proof, I forgot to photo the fogging when the drone landed (
2022-7-21
Dryvise
Russia
Found a more detailed video:
In addition, you can lubricate the ring with a sealing lubricant, such as silicone for a coffee maker. I have such a lubricant for the O-rings of a waterproof lamp. Only a very, very thin layer!
Oleg13 I can only check in the evening. I will write.
2022-7-21
Oleg13
Russia
Dryvise Posted at 7-21 01:04
Found a more detailed video: https://www.youtube.com/watch?v=UDQeTG-ayB0
Thank you!
2022-7-21
Dryvise
Russia
Date: 04\2022
As I said, there were no problems, but I decided to check. The rubber ring was installed incorrectly.
2022-7-21
PerlanSwed
Flight distance : 1130577 ft
Sweden
Same problem here
2022-7-22
djiuser_heZNljQXiCLG
Brazil
2022-9-25
Brazil
djiuser_heZNljQXiCLG Posted at 9-25 11:02
In What whether conditions?
2022-9-25
Vương Sơn
Flight distance : 883320 ft
Vietnam
Cao su vòng đệm thay thế sẽ được xử lý vì error on
2022-11-8
Geo_Drone
Flight distance : 2676129 ft
Romania
Is still there for APRIL and MAY releases.
Seems to be gone starting June production, probably the idiot Chinese person from assembly line was fired )))))))))
2022-11-9
gnirtS
Flight distance : 5712575 ft
Pretty sure the o-ring inside mine is the wrong size for the groove.  Its a very loose fit and is never going to seal properly.  (bought in May).
I wonder if later models used the correct size o-ring.
2022-11-9
hallmark007
Geo_Drone Posted at 11-9 02:52
Well you had a go yourself and you weren’t very successful, . How difficult can it be to fit an O ring. ;+)
2022-11-9
gnirtS
That depends if the supplied o-ring is the correct size.  I suspect on my April model it's not given the loose, slack engagement.
2022-11-9
Beta5K
Flight distance : 196880 ft
Mine's May model. Haven't had any fogging issues, even when I took it up high in the mountains and in -9C weather (for a short time around 5 minutes).
2022-11-9
Geo_Drone
Romania
hallmark007 Posted at 11-9 06:40
Is not only O-RIng, is also the seal from back of camera...Also they put O-Ring but forget to clean the lenses inside, so a rainbow appear instead of fog )))))))
2022-11-10
Berhatz
Flight distance : 667575 ft
Russia
Привет! Партии с сентября - исправили конструктив и все ок. Но теперь у них косячные пульты RC - у меня и трех людей с одной партии брак контроллера питания. Естественно, DJI все отрицают.
2022-11-10
Do you travel
India
I bought DJI Mini 3 pro 2 months ago, i used it for few times only, now only I noticed there is a fog is foaming inside the camera once the drone used. Please kindly let me know how to solve this problem.
2023-6-8
12Next >
