Which mode does stress the motors?
726 2 2022-7-20
Marc68
hello,
which mode does stress the motors more than usually / reduces the stabilization effekt like than in standard mode?
- briefcase?
- underslung?
- flashlight?
many thanks & best regards
marc
2022-7-20
Indio
Flight distance : 303373 ft
Austria
none of the above, mainly incorrect balancing
2022-7-20
XinRain
Belgium
Hello there,
As long as you respect the max amount of payload the gimbal can handle and properly balanced well, you should have no problems with it. Unless you go crazy with the gimbal.
Everytime I see people with a gimbal going from flashlight mode to underslug mode halfway through and they start turning the Pan, it's like dislocating its neck.
2022-7-29
