XinRain
Belgium
Hello there,
Go to your Dji Ronin app -> Motor Parameters -> Open more Parameters ▽ -> press Joint Angle and keep it pressed, wait for about 5 seconds.
Then a pop-up screen will come up about Offset Calibration, simply follow the instructions.
If anything goes wrong with the parameters, go to main menu of the Dji Ronin app look for Status scroll all the way down you should see Restore Gimbal Parameters and try again with the Offset if necessary.
Hope this helps.
Kind regards,
XinRain |
