Labroides
Flight distance : 9991457 ft
gary h Posted at 7-22 20:07
Labroides -- I flew the drone several times today and tested the RTH when landing. Every time it landed within 2--4 inches of the center of the drone's launch pad. I flew again just now, about three hours after the last successful flight and landing. The drone was about 100 feet north of its landing pad and I clicked on RTH. The drone proceeded to attempt an auto-landing 28.9 feet north of the landing pad. So I went into the settings of the RC Pro to see where the home point was set. According to the map, the home point was located correctly in the middle of the deck on the south side of the house, which is exactly where I took-off from, and from where I locked-in the home point. But that is not where the drone tried to land. It tried to land on the north end of the house, 28.9 feet from the home point. This time I did not perform an IMU calibration, but instead flew the drone to about three feet above the landing pad and told the drone to update its home point to this location. I then climbed to about 50 feet in altitude and flew away to the south. Upon executing RTH again, the drone landed in the proper location. I repeated taking-off and landing several more times and all worked fine. I still haven't been successful in retrieving the controller logs, but will eventually figure it out. I suppose it's possible there is a problem with the GPS. The Mavic 3s have had GPS problems since their November 2021 launch, but all has supposedly been fixed with a firmware released in May 2022. The problem did not involve accuracy, but instead had to do with how long the drones were taking to lock-in a home point. Times were taking multiple minutes, up to maybe 5--10 or more. I haven't heard that anybody else is having an RTH accuracy problem with their Mavic 3s.
RTH is very, very reliable.
It doesn't randomly land in odd places.
There will be a simple explanation waiting to be found in your flight data.
I don't have one of those controllers to check, but others have managed to get flight data from them so it must be possible.
Did you see these detailed instructions for some of DJI's other integrated tablet/controllers?
https://forum.phantomhelp.com/t/ ... o-your-computer/256
Yours should work in a similar way.
I suppose it's possible there is a problem with the GPS. ...
The Mavic 3 GPS issues were solved a couple of months back.
But they weren't about GPS accuracy.
If you have up-to-date firmware, your M3's GPS should be working as well as (or better than) any other DJI drone.
What's your launch point like with respect to having a clear skyview for satellite reception?
Is there a clear horizon everywhere you look or is much of the sky blocked by buildings, trees etc?
I don't like guessing, but what I suspect might be happening is that the drone isn't recording a homepoint before launch, or GPS is marginal there and it records a tentative homepoint and a little later updates that when it gets good GPS reception as it's flying out.
The recorded data will quickly show if it's that or if not, what is actually happening.
