hallmark007
Flight distance : 9812789 ft
UgoFly Posted at 7-29 07:54
The Mavic 3 starts and stops abruptly and if the subject to be shot is close enough the defect on the shot is evident. If, on the other hand, what you are shooting is far away, it is clear that the defect is not visible. If you want to see a shot ruined by this defect, just look at the one I posted on the post. I challenge anyone to take a moving shot with the Mavic 3 and then slowly stop and continue shooting, it's impossible. If, on the other hand, I needed to stop abruptly, I could always do as I do with other drones and that is to move the sticks in the opposite direction in order to give a force contrary to the movement.
I seen what you posted above and was simply amazed that you wanted the drone to fly closer “out of your control” instead of flying as close as you could knowing your drone will stop. The example makes no sense and Im not sure why you would risk your drone crashing into something after you voluntarily gave up control. So what you need to do is fly as close as you would with your old drone and you won’t need to reversing trying to save a collision. Again some dji drones had a cinematic feature that allowed “a measured continuation of flight” that might make more sense. But yes I’m quite happy to have my drone stop when I lay off the sticks and I have no problems filming with Mavic 3.
Almost all film makers on your shot above would have started close to the statue and moved slowly backwards, reverse the footage and you will get much smoother footage of that shot...
