MIMO on Pixel 6 will not load
3487 12 2022-7-25
colinsmith18
Flight distance : 61047 ft
I have been successfully using the Mimo app with my new OM5 until last week. When I click the app on my Pixel 6 it now won't load. I've uninstalled then reinstalled with the current APK but it still doesn't run.
When will this be fixed?
2022-7-25
Zero-Sixx
The app is also buggy on my Pixel 6. It does work somewhat, but far from great. Please do me a favor once you get the app running; record a selfie video in 1080P / 30 Frames per second mode (this is the default, no need to change anything).
The video looks like it’s stuttering, very choppy and low frame rate, I think it is because the app does not work properly with the Pixel 6. I would love for you to test this as soon as you get it running on your phone. If you also have it, we might be able to report this problem to DJI and see if there is a solution.
2022-7-25
colinsmith18
Zero-Sixx Posted at 7-25 11:46
I am unable to load it so cannot record a video!
2022-7-25
Zero-Sixx
colinsmith18 Posted at 7-25 13:44
I understand, did you download the app from their own website ?
I removed it and re-install / downloaded it from here: https://www.dji.com/se/downloads/djiapp/dji-mimo
Latest version seems to be 1.7.2.0
Let me know if you get it working, would be interesting to see how the camera app performs on your pixel.
2022-7-25
colinsmith18
Zero-Sixx Posted at 7-25 13:48
I have version 1.7.2. My issue to repeat is that Mimo used to work but no longer does. It used to work very well with the Pixel 6 camera. I was very happy with the video quality.
2022-7-25
Ray-CubeAce
colinsmith18 Posted at 7-25 23:46
My Galaxy phone will download the app but refuse to install it.
I get the message 'Unverified App', and the install is abandoned.
I am stuck on version 1.5.4 which is the only one that will load.
2022-7-27
DJI Stephen
Hello there colinsmith18. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try to uninstall and reinstall the DJI Mimo ( https://www.dji.com/downloads/djiapp/dji-mimo ) application on your mobile device for us to be able to isolate the said issue. In addition, kindly please save all of your photos and videos before uninstalling the DJI Mimo application on your mobile device for you not to loose the said files. If the issue persist kindly please try using a different recommended mobile device for us to be able to isolate the said issue. Thank you.
https://terra-1-g.djicdn.com/851 ... ibility_List_en.pdf
2022-7-27
DJIisgarbage
Finland
What a load of crock this company is.
2022-7-28
colinsmith18
DJI Stephen Posted at 7-27 19:50
https://terra-1-g.djicdn.com/851d20f7b9f64838a34cd02351370894/om-5%E6%89%8B%E6%9C%BA%E5%85%BC%E5%AE%B9%E5%88%97%E8%A1%A8/DJI_OM_5_Mobile_Phone_Compatibility_List_en.pdf
Thanks for the reply.
I have already uninstalled and reinstalled the app - see my very first post - but I have done it again as you suggest. However the app will still not load. I click the app and nothing happens. I've downloaded the app from your web site and can see that it is version 1.7.20. I am running this on a Google Pixel 6 which is on your supported device list.
Can you please get this fixed? The MIMO app was running successfully before so I don't know what has changed. Thanks.
2022-7-29
Christian Stommel
Flight distance : 105702 ft
Same here - not working with Pixel 6.
2022-7-31
djiuser_HWzvhUbhxjyl
Singapore
Likewise, the app doesn't run on Pixel 6 regardless how many times I uninstall or reinstall it.  Is there an older version that works?
2022-8-13
colinsmith18
djiuser_HWzvhUbhxjyl Posted at 8-13 01:50
I've tried older versions and they don't work on my Pixel 6
2022-8-14
AGK
It is now January 2023 -- any updates on this situation?
2023-1-17
