Gimbal / Drone fault or Mini 3 limitation in wind?
1287 15 2022-7-25
djiuser_kyEY75nfoVCr
Flight distance : 776325 ft
I have had some odd gimbal movements when flying in wind. Please see video
The wind was round 21 km/h. Is this normal or do I have a fault with my Mini 3 and has anyone else experenced this?
2022-7-25
Goggles Pisano
Flight distance : 8810745 ft
Looks like bird attack ...
2022-7-25
Goggles Pisano Posted at 7-25 11:31
No birds in the area
2022-7-25
Goggles Pisano
There is a bird in the background of video...
2022-7-25
Goggles Pisano
Just a idea, don't think its the wind...
2022-7-25
Goggles Pisano Posted at 7-25 11:53
I can assure you I was watching the drone from just below it and there was no bird attacking it.
2022-7-25
chillibadger
Flight distance : 233064 ft
djiuser_kyEY75nfoVCr Posted at 7-25 12:07
Looks like a fault should be silky smooth
2022-7-25
chillibadger Posted at 7-25 12:08
I was getting high wind warnings at the time but as I said the wind was around 21 km/h.
2022-7-25
Goggles Pisano
Could be wake turbulence created by drone on the way down ..
2022-7-25
Mobilehomer
Flight distance : 18135846 ft
Not sure what causes it, probably quick gust of wind. I have seen this on both Mini 2 and Air 2S. Not very common, most of the time either are rock steady.
2022-7-25
hallmark007
Flight distance : 9827923 ft
You may need to calibrate your gimbal. I’d suggest you return the drone if it doesn’t stop. Its not wind or sudden movement its an involuntary movement of the gimbal. I’ve seen this with other drones usually calibration of the gimbal will sort it.
Its not a bird attack and its not a gust of wind.
2022-7-25
CloudVisual
Flight distance : 97545420 ft
I have experienced this exact issue and solved it (as much as I can). It isn't a bird, or something you need to raise a fault with DJI.
Simply, it is the gimbal reaching the end point when the wind hits the drone side on and causes the gimbal to exceed its limit.
If it is windy (12+MPH) avoid facing the left or right hand side of the drone into the wind for any downward shot, the gimbal has a much greater range of movement if it's faced into or with the wind behind it.
If you want to prove it, just hold the drone in your hand and simulate this without taking off and you'll see for yourself.
2022-7-25
CloudVisual Posted at 7-25 12:55
Makes perfect sense. It only seems to happen when windy but has happened a few times. I was going to try the hand hold test
I was shooting in Mastershots mode at the time so I didn't have a say in the direction I was facing lol.
2022-7-25
DAFlys
Mine does this in strong wind at -90.    The Mini2 was terrible for it,   I think this is normal.
2022-7-25
DJI Stephen
Hello there. I am sorry for the trouble this has caused and thank you for reaching out. May we please know if you have received any error message or error codes on the DJI Fly application when this happened? In addition, the DJI Mini 3 Pro has a Maximum Wind Speed Resistance of 10.7 m/s ( Level 5 ). Thank you.
2022-7-27
Montfrooij
Flight distance : 2560453 ft
Yes, looks like wind.
When the gimbal is down, it has very little room to correct with the gimbal, so the drone has to do the work with the motors, which has its limitations.
This is not a bug, more a limitation of the tiny size and power of this drone.
Mini 2 is much worse btw at 90 degrees.
2022-8-15
