We need regular 10 bit color profile
1913 3 2022-7-25
Moshe.mmm
Flight distance : 1320098 ft
Israel
Please make it for next firmwere.
Thank you.
2022-7-25
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. I will take this as a suggestion of yours and will forward it to our designated team for attention. After the evaluation of the engineers, significant suggestions or requests will be implemented via the firmware update, app update, etc. For any updates, please stay tuned to the latest news on our DJI official website at www.dji.com. Thank you for your understanding and support.
2022-7-25
Mzp
Hi Moshe, Mavic 3 supports HLG 10 bit HDR BT.2020 and D-Log 10bit rec.709 , why would you need Normal color profile recording in 10 bit depth (if that is what you mean) instead of Normal recording in 8 bit depth as it is today?  Fyi Mavic 3 Cine supports recording Normal color profile recording 10 bit depth when using ProRes 422 codecs and to be honest it is inferior to HLG or D-Log. Not sure if you have Mini 3 Pro, but the end result is the same as if you recorded D-Cinelike on Mini 3 Pro in 4k 60fps, which is 10 bit color. In any case Mavic 3 Cine already supports this in ProRes 422 and the end result is not much different than if it were 8 bit color. I mean yes you can get color gradients in the sky and clouds, but in terms of dynamic range since this is not a log profile, you are getting a range similar to what Normal 8 bit offers with slight improvement due to 10 bit color on M3Cine. Wanted to ask you why you wouldn't want to use HLG or D-Log , which are by far superior to what you are asking for. Hope this helps.  Thanks, Mike.
2022-7-25
Geo_Drone
Flight distance : 2676129 ft
Romania
With LOG profile you need to make only 1 step in Davinci free software in order to have it 10bit Rec709 Wide Gamut.
Is called Color Space Transform.
That simple !
Learn basic editing.
2022-8-3
