How to upgrade battery firmware 1.3.0 inspire1??
1350 4 2015-8-5
Filmax
Norway
Can someone explain the procedure. How to update the battery?
Has already updated RC and I1 with firmware 1.3.0
2015-8-5
snathla
Flight distance : 4688222 ft
You have to leave the .bin file on the SD Card and run each battery thru the Inspire (turning on/off), it goes thru the same "d d d d" and then d...dd and you know they are done.  It does  not take too long for each battery to be updated
2015-8-5
Filmax
Norway
snathla@gmail.c Posted at 2015-8-5 22:21
You have to leave the .bin file on the SD Card and run each battery thru the Inspire (turning on/off ...
Thanks
2015-8-5
pandppurchase
Make sure you delete the text files every time you update the battery firmware otherwise it may ignore the required update for the battery.
2015-8-5
tapboxer
Flight distance : 824672 ft
and make sure the RC is off
2015-8-5
