What is this cable for?
3307 10 2022-7-29
swild
Flight distance : 141932 ft
Hey everyone,
I bought the DJI Lidar focus thing, and I'm at a loss for what this cable is for.
The manual calls the cable the "LiDAR  Range Finder Control Cable, but it doesn't say anything else about the cable in the manual or instructional videos. The range finder can be operated with a normal USB-C to USB-C cable, so I'm not seeing the need for it.
Any suggestions would be greatly appreciated.
Cable
Cable
2022-7-29
XinRain
Belgium
Hello there,
That cable is used to connect to your motor so it can be charged through a third party battery for extra battery life, for your whole Lidar system.
Hope this helps.
Kind regards,
XinRain
2022-7-29
swild
XinRain Posted at 7-29 11:16
Hello there,
Are you sure?
On one end, it has a sticker that says "To LIDAR", and on the other, it says "To RS3 Pro".
2022-7-29
XinRain
Belgium
swild Posted at 7-29 13:48
Are you sure?
Can't see the connections too welI so I might be wrong, Can you tell me the connection type below on the picture?
2022-7-29
Indio
Flight distance : 303373 ft
Austria
2022-7-29
XinRain
Belgium
Are you sure?
If it's a usb c to usb c then it's just the same function as the normal multi usb to usb c cable. except this one prevents the display of becoming grainy or flickering.
2022-7-29
swild
XinRain Posted at 7-29 14:23
I'll test the cable this weekend for powering the setup off the gimbal. Until then, I don't think anyone knows what that cable does.
2022-7-29
XinRain
Belgium
swild Posted at 7-29 14:37
This is the only clue i've found so far.
https://www.heliguy.com/blogs/knowledge-base/when-do-i-need-to-use-the-dji-lidar-control-cable
2022-7-29
illuminatedRS
XinRain Posted at 7-29 14:44
DJI - any followup on this?
2022-9-2
Achyutanand
India
I have been trying to figure the same. DJI team, any information on this will be really appreciated since we all seem to be only guessing here.
2023-4-21
Achyutanand
India
got this as reply from DJI support team on email,  sharing this for everyones reference:
"The function of LiDAR Control Cable is the same as that of USB-C control cable. So you can also directly connect Lidar and gimbal with usb-c control cable.
However, the black box in the middle of the LiDAR control cable can play the role of rectification, filtering and anti-interference, so we have optimized and upgraded the cable.
This cable is essentially a USB-C cable, but there is an additional anti-interference part."
LiDAR Control Cable
LiDAR Control Cable
2023-4-26
