Sean-bumble-bee
Flight distance : 15997 ft
Edit 2.... It seems fair to say that I was not the only person to labouring under the misconception of what will happen with the Mini 2. Which is what I wanted to discover.
I was flying in the expectation that the climb to RTH would be cancelled and the drone would then start its flight home.
Attached are a screen capture of the app message and a chart from CsvView showing the throttle, flight mode and height.
I needed a live screen view to judge how low I could descend over vegitation before starting the RTH, it didn't occur or to me to set the camera to manual exposure before starting the climb, sorry for the white space.
EDIT 3. From the manual of the Mini 3 which is perhaps an interesting explanation of the 'new' behaviour.
"When the aircraft is ascending or flying forward, push the control stick completely in the opposite direction to exit RTH, and the aircraft will brake and hover."
With out looking it up or testing or looking at the answers provided by, hopefully, others i.e. press the ''Post Reply'' button below. PLEASE just say/write what you think will happen when.....
I am interested in finding out what people think without looking it up.
Edit 1. For those who have posted and those who have yet to post, could you please add the drone's firmware version and the App version?
The RTH ceiling is high, say 80+m/262ft, the Mini 2 is 200m/656ft from the home point and at a indicated height of 10m/33ft. You trigger an RTH and after the Mini 2 is above 20m/65.6ft you briefly close the throttle, either completely or partially?
THanks.
Please do not publish the results of testing.......yet.
Ultimately I am interested to see how many people's belief is wrong. That is not a condemnation, hopefully all will become clear later on.
I have done my own test and am not commenting on that ......yet, hence post #9 being about my expectations and only those expectations.
