dji simulator error 005_000 {000/0114}
5927 7 2022-7-31
shoot2thrill
Flight distance : 185289 ft
Philippines
need help regarding i get error  "dji simulator error 005_000 {000/0114}"
un-installed and re-installed but same problem.
2022-7-31
DJI Susan
Hi there, if the file error “005_000” occurs, the reason is that the folder cannot be created in the specified path for saving the installation package.
It is recommended to change the save path (or choose another disk), It is recommended to install to a non-system disk and ensure that there is enough disk space. See if this helps.
2022-7-31
shoot2thrill
Philippines
DJI Susan Posted at 7-31 01:29
did what you sugested but i get same problem... any other suggestion?
2022-8-2
DJI Natalia
shoot2thrill Posted at 8-2 15:51
Thank you for the update.
We have confirmed with the team, if the problem still can not be solved, the permission to create a new folder may be blocked. It is recommended to contact the technical support of the corresponding computer for help.
2022-8-2
djiuser_8DWoiQ5uthy0
Argentina
Does anyone know an alternative simulator?
2-24 09:36
djiuser_8DWoiQ5uthy0 Posted at 2-24 09:36
Hi there, may I ask if you encountered any issues with the DJI Flight Simulator? If there is anything we can help you with, please let us know.
2-25 01:01
Argentina
DJI Mindy Posted at 2-25 01:01
Hi Mindy, yes, the problem with DJI Flight Simulator is that is not being developed so I'm not able to use my RC2 for practicing.
I was asking for an alternative flight simulator (not FPV) because I do own an FPV-type controller and I might use that to practice flying a DJI mini 4 pro type of drone in sport mode.
Thanks
3-5 11:37
djiuser_8DWoiQ5uthy0 Posted at 3-5 11:37
Thanks
We are sorry that DJI Flight Simulator is only compatible with the following remote controller models. We will forward your feedback and suggestions to the corresponding team for evaluation.
3-5 23:23
