Mosaics to increase picture size...
1745 32 2022-8-1
Bussty
Flight distance : 320951 ft
New Zealand
I have been wanting to test the Mini 3 Pro for a while to do Mosaics. Mosaics unlike panoramas rely on the stitching software to stitch images taken metres apart. Classic case is a tree lying in a river I can take just one shot using 48MP mode or I can switch the long edge of sensor around to match the short edge of the image I'm taking then keeping parallell to the tree fly over taking images as I go. Rather than just one image I now have 5 or 6 that I can stitch together to make a higher detailed image.
Normally panoramas are taken from the same spot and the camera raws or changes pitch but in this case the camera stays put and the drone moves laterally over the subject.  Case in point (not you won't see any quality differenc here as images are too low res but full size images are here...  Fullsize images
So here is the single tree shot...  (note all images have had no processing done accept for downsizing to fit here)
Now lowering the drone. I could have gone lower to match up the longest edge of the sensor with the short edge of this image but was a little woried about flying over water. So final image could have been even higher quality... Here are 5 shots moving along the trees total length...
The images are then loaded into PTGUI using these changes...
So to stitch mosaics, proceed as follows:
  • Start a new project and load your source images
  • Switch PTGui to Advanced mode using the Advanced button in the side bar
  • Go to the Lens Settings tab and set the Lens type to Rectilinear. Set the Focal Length to a high value (e.g. 1000mm).
  • In the Control Points menu choose 'Generate Control Points'
  • Go to the Optimizer tab. Deselect the 'Optimize lens focal length' checkbox. At 'Minimize lens distortion', choose 'Heavy'.
  • Press the Run Optimizer button (at the bottom)   When it asks if you want to run "Initialise and Otimize" don't!
  • Now go to the Panorama Editor window by pressing Ctrl+E (Windows) or Command+E (Mac). First press the Center Panorama button, then press the Fit Panorama button.
Your mosaic is now ready to be stitched at the Create Panorama tab.
And the result...
Final
Final
If you compare the fullsize images you'll see a nice difference in quality. The magic of stitching software allows you to do this and DAFlys reports you can do in Lightroom also. I would avoid subjects that are moving (though the water was moving here), subjects that have considerable height (parallax will eventually get you!) and just don't go too close. If you have masking functionality in your stitching software it's pretty easy to correct any small issus that may arise e.g a twig moving in the water being hard to join properly.
2022-8-1
forbsie
That looks great! Did you have any parallax issues when stitching the images?
2022-8-1
Bussty
New Zealand
forbsie Posted at 8-1 17:51
Thanks Forbsie amazingly not really, only thing I had to do was paint mask in one of the tips of the tree as was moving. It baffles me how the software can do it!
Same technique applied here...
Original of this just under 8000 pixels (Mini 1)
2022-8-1
Blériot53
Flight distance : 6188465 ft
Very effective. You seem happy with a great result    Some powerful software at work.  I couldn't justify myself the cost of PTGUI for my dabblings - and I wouldn't have the patience to go to all that trouble for a shot. I guess I'm just a lazy point-and-press guy
2022-8-1
Bussty
New Zealand
Blériot53 Posted at 8-1 22:23
Indeed... you should talk to DAFlys he said he does something similar in lightroom? Cheers Bussty
2022-8-1
Blériot53
Bussty Posted at 8-1 22:55
Again, it's the patience I lack and the concentration makes my brain ache
I'm in regular contact with David, he is pretty knowledgeable
2022-8-1
Bussty
New Zealand
Blériot53 Posted at 8-1 23:10
Makes my brain aches too sometimes, so not alone
2022-8-1
Blériot53
Bussty Posted at 8-1 23:11
Makes my brain ache too sometimes, so not alone
2022-8-1
DAFlys
Great example Bussty,   I just posted a version I made with Lightroom over in the works section.
2022-8-1
DAFlys
You could always try ICE from Microsoft its free.
https://web.archive.org/web/2019 ... -64-bit-Windows.msi
2022-8-1
Blériot53
DAFlys Posted at 8-1 23:29
https://web.archive.org/web/20190223050207/https://download.microsoft.com/download/7/3/9/73918E0B-C146-40FA-B18C-EADF03FEC4BA/ICE-2.0.3-for-64-bit-Windows.msi
Thanks for the link David.
I had that on one of my old computers that went to the Bitlocker in the Sky
Didn't have much joy with it trying to stitch 180 panos.
I'll download it to this laptop for a few more experiments
2022-8-1
DAFlys
Blériot53 Posted at 8-1 23:36
Well,  just start small and see how you go.
2022-8-1
Bussty
New Zealand
DAFlys Posted at 8-1 23:40
Indeed Bleriot you have got this!!
2022-8-1
Blériot53
Next time I can get out, maybe.
Have an earworm
2022-8-1
DAFlys
Bussty Posted at 8-1 23:43
Im sure @Blériot53 will have a go as soon as the rain stops.
2022-8-1
Blériot53
Well thanks for the encouragement guys.
Now I just need the rain to STOP !!
2022-8-1
DAFlys
Blériot53 Posted at 8-1 23:48
What about a wet suite for the drone - https://www.ebay.co.uk/itm/184575377085
2022-8-1
Blériot53
DAFlys Posted at 8-1 23:48
Noted
2022-8-1
Blériot53
DAFlys Posted at 8-1 23:49
It's me that would need the wetsuit at the moment
2022-8-1
forbsie
Bussty Posted at 8-1 18:02
That's very impressive, I will have to give it a try .. I actually thought parallax would have caused problems with stitching in the tree image, but not so much at higher altitudes. I have Lightroom and a couple of other application that stitch images, so you've given me a new project ;)
2022-8-2
Bussty
New Zealand
forbsie Posted at 8-2 00:52
Nice! Good luck and make sure you show us :-)
Cheers
Bussty
2022-8-2
DJI Paladin
Flight distance : 318 ft
Magnificent work, Bussty! Thanks for sharing this with us.
2022-8-2
DowntownRDB
Flight distance : 1722 ft
Great shot Bussty.    Thanks for sharing your process for the mosaics.
2022-8-2
DowntownRDB
Blériot53 Posted at 8-1 23:47
Have an earworm
https://www.youtube.com/watch?v=AUDPWiv28MI
Oh no you didn't just plant this earworm.
Now I'll be hearing that all morning.
2022-8-2
Blériot53
DowntownRDB Posted at 8-2 05:26
I do like to sew a little mischief here and there
2022-8-2
DowntownRDB
Blériot53 Posted at 8-2 05:30
    You sure do.
2022-8-2
Bussty
New Zealand
DJI Paladin Posted at 8-2 02:03
Thanks DJI Paladin :-)
2022-8-2
Bussty
New Zealand
DowntownRDB Posted at 8-2 05:22
Thanks Downtown, even though the Mini 3 Pro has a fairly small sensor being able to place it anywhere means we can build up really top quality shots in some cases
2022-8-2
DowntownRDB
Bussty Posted at 8-2 15:51
My pleasure Bussty.
No doubt about the Mini 3 being a small but very capable drone.
2022-8-3
DJI Paladin
Bussty Posted at 8-2 15:39
Always my pleasure, Bussty. Have a nice day ahead.
2022-8-5
Montfrooij
Flight distance : 2560453 ft
Very interesting to see!
2022-8-16
Bussty
New Zealand
Montfrooij Posted at 8-16 00:04
Thank you! Doesn't work on all subjects if you are too low or the subject is quite high stitching can be tricky but you have a particular subject and you need to go big is a handy technique
2022-8-16
Montfrooij
Bussty Posted at 8-16 01:38
Yeah, I have to give it a go!
2022-8-16
