weird vibrations in the gimbal
526 2 2022-8-2
Abdra
Flight distance : 9786952 ft
Egypt
i get weird vibrations from the gimbal (video attached)
i tried calibrating everything (gimbal  , imui , sensors) with no solution
my drone is mavic air2s
2022-8-2
wa.jesse07
Flight distance : 4686545 ft
Probably sending the drone in would be a good idea. The ribbon cable is damaged.
2022-8-2
DJI Susan
Hi Abdra, sorry for your case. May I know if the drone has experienced any accidents previously? After checking, I may suggest that you send the drone back for further service.
If you are located in Egypt, you may need to contact the local retailer for assistance.
Or you can try to contact our support on the following link for further help http://www.dji.com/support
2022-8-2
