What is Occusync?
6078 38 2022-8-2
DreamWorks
The poll pretty much speaks for itself...
Hindsight i should have put, DJI's own unique transmission system (not WiFi)
Single SelectVote, Total 51 people participate in voting
Your user group with no voting privileges
2022-8-2
davidy61
Flight distance : 57037 ft
Maybe an "I have no idea" choice would be helpful as that's where my vote would be.
2022-8-2
DreamWorks
davidy61 Posted at 8-2 23:08
Sorted for you. lol
2022-8-2
DreamWorks
From what i can gather, Its just a version of wifi, with a rolling channel/frequency hop, nothing special really
2022-8-2
NutHouseDrone
Flight distance : 1206654 ft
DreamWorks Posted at 8-2 23:13
Where did you gather that?  Or why do you assume that?
2022-8-2
DreamWorks
NutHouseDrone Posted at 8-2 23:21
Because thats what it is, the only difference between the Mini and 2 & 3 Pro is that the 2 & 3 Pro use on the fly channel and frequency hopping.
Its using the same as your homes router, 5.8ghz and 2.4ghz, to me, that is WiFi
If you do not think it is WiFi, what is it? I am open to learning something for sure
2022-8-2
Mini-G
Flight distance : 673862 ft
At the end of the day isn’t it just radio signals… DJI just works with tried and tested 2.4 gigahertz (120 mm) UHF and 5 gigahertz (60 mm) SHF radio bands.
2022-8-2
DreamWorks
Mini-G Posted at 8-2 23:30
Yep, exactly.
2022-8-2
DreamWorks
Here is someone else's take on it, I'ved started it where it's relevant and cuts out a lot of the jibba jabba..
2022-8-2
NutHouseDrone
DreamWorks Posted at 8-2 23:28
Just because they use the same unlicensed frequency bands doesn't mean it is WiFi or even similar to WiFi.  The only thing that is certain is that they share the same RF frequency bands, along with many other wireless devices that are most certainly not WiFi.  WiFi means something very specific.  Look up the definition... the WiFi wiki page has a pretty detailed description.
Obviously it works far better than just WiFi.  Now, maybe you are right and they "just" modified WiFi.  But that is why I was asking you where you gathered that information or why you thought that (just because it has same frequencies?).
And even if they did "just" modify WiFi, what does it really matter because it isn't WiFi anymore   They have at least tailored it to be something unique for this particular application.
2022-8-2
davidy61
DreamWorks Posted at 8-2 23:12
Sorted for you. lol
Thanks. Voted now
But I may watch the YouTube video and learn something.
2022-8-3
Bashy
Flight distance : 2354357 ft
I chose WiFi, even if dji modified how we perceive WiFi, it is fundamentally WiFi at the end of the day
2022-8-3
Labroides
Flight distance : 9991457 ft
A wifi drone has a limited range, topping out at 1000 metres in perfect conditions and less than half of that most of the time.
Its picture gets sketchy and starts to break down as you get further out.
A drone using Occusync goes for 10 kilometres and keeps a clear image on the screen all the way out.
But you think Occusync = Wifi ?
2022-8-3
DreamWorks
Labroides Posted at 8-3 02:38
Yep, sure do unless someone can sure me that Occusync is something other than it.
2022-8-3
MySky
Flight distance : 364902 ft
Even if Occusync uses the same frequencies like Wifi to be in line with the official free frequency ranges, it is completely different in case of HF transmission and protocol.
Here is some more In-depth on occusync.
https://forum.dji.com/forum.php? ... id=72819&pid=575341
And here:
2022-8-3
Labroides
DreamWorks Posted at 8-3 03:31
I suggest you read my post again.
I can't see how to make it any clearer.
But if you want more detail try these:
https://expertworldtravel.com/what-is-dji-ocusync/
http://djibestdrones.com/dji-ocusync-2-0/
2022-8-3
Mobilehomer
Flight distance : 18150351 ft
It is their proprietary algorithm using the wifi signal as a carrier. Who cares how it works? It works!
2022-8-3
DreamWorks
So what i can gather then, thank you for the links by the way, is that Occusync is software working off of wifi hardware, or have i misread?
OcuSync on the other hand is more of a software based system and more of an SDR. It’s able to work on generic off-the-shelf hardware so eisting Wi-Fi hardware, for instance, is able to use the OcuSync system. It allows DJI to keep the hardware costs down because they’re not having to make custom hardware or expensive FPGAs. This allows them to use a far more compact packaging because many of the SOC’s and the processes we use in all devices these days, like in smartphones and in these drones, already have radio hardware onboard that is designed for Wi-Fi. So DJI are able to leverage existing hardware to be able to get the same type of system that they originally designed with Lightbridge.
That came from your 2nd link Labroides
2022-8-3
DreamWorks
Mobilehomer Posted at 8-3 05:26
Its come down to because i keep calling it wifi, to me that's what it boils down to, and some have been saying its not, it looks like from what i have just read and as you've just said, that it is actually software working with wifi
2022-8-3
NutHouseDrone
DreamWorks Posted at 8-3 05:34
So quit calling it wifi
Based on the aritcle and video, I think it would more accurate to say that it is software (in fact, an SDR) that uses the same hardware that is typically used for wifi.  Different than saying it is using wifi or working with wifi.
2022-8-3
TonyPHX
Flight distance : 11229610 ft
Is this a technical question or more of a philosophical question?  What is Occusync really?  Does one ever truly know Occusync?
2022-8-3
MySky
TonyPHX Posted at 8-3 10:16
Occusync is a SDR (Software Defined Radio) system designed by DJI using propriatary Wifi hardware to build a cheaper and more flexible system which can be more easily updated or upgraded instead of designing each time new and more expensiv hardware.
Best example is the RC-N1, which can be used with different Drones and Occusync versions, just by simply  updating the FW.
Also the protocol and frequency modulation is different from Wifi systems. (See links and video above)
2022-8-3
TonyPHX
MySky Posted at 8-3 11:27
So it's kind of like wifi.  Cool!
2022-8-3
DreamWorks
NutHouseDrone Posted at 8-3 08:19
Never gonna happen, it is WiFi only tweaked with software.
2022-8-3
Labroides
DreamWorks Posted at 8-3 19:39
Tweaked?
By now it's clear that you aren't interested in learning anything and just want to troll.
2022-8-3
DreamWorks
Labroides Posted at 8-3 20:40
Tweaked?
Great talk...
2022-8-3
DJI Stephen
Hello there DreamWorks. Good day and thank you for reaching out. The DJI Mini 3 Pro supports the DJI O3 ( Ocusync 3.0 ) Video Transmission System that uses an all-new solution and upgrades dual antennas to four antennas to bring FHD video transmission at distances of up to 12 km ( FCC compliant and with no obstructions). Additional anti-interference capabilities further improve transmission stability in cities and other complex environments. ). Thank you.
2022-8-3
Occams Razor
Flight distance : 514478 ft
Technically, Occusync is not WiFi.   You are confusing WiFi with RF bands.   The RF bands of 2.4 and 5 GHz do not equate to WiFi - they are just radio frequency ranges that the WiFi standard uses.   WiFi is based on the IEEE 802.11 standard and can use up to the 60GHz bands.   Occusync uses the same frequencies but has a different protocol that can extend the transmission range.  In theory, Occusync could have been based other RF bands but because the hardware for 2.4 and 5 Ghz are readily available and cheaper, DJI took advantage of that situation.
2022-8-4
Bashy
Occams Razor Posted at 8-4 18:50
Now that right there is how you explain something in laymans terms and i understand it, thank you.
What is interesting is how many of us actually thought of it as WiFi.
2022-8-4
Geebax
You got it pretty close. DJI do not use WiFi, they are simply using the unregulated bands available to them in most countries of the world, and WiFi is probably the only well known and most 'famous' user of those bands. But they are also used by Radio Control models, garage door openers, wireless baby monitors and a thousand other applixations, all of which are not considered essential communications. They have been allocated two bands and left to fight it out as to who interferes with each other, as one of the caveats in the license use agreement is that no one user will be given priority over another, they have to learn to get on with one another. So, it is incorrect to call the transmission system 'WiFi'.
In order make their system a bit more tolerant to interference from the other band users, DJI developed Occusync, which is not strictly speaking a name for the whole process, because the radio communication between a DJI drone and its controller consists of four channels of data, only one of which contrains the Occusync stream, from the aircraft to the remote control unit. In the Occusysnc system, only the video system components are contained in the stream and it is encoded as a digital data stream containing a system of forward error correction bits, to make the signal interference tolerant.
Forward error correction (or FEC) is a technique where additional data bits are added to the stream so that if some bits are lost due to interference, the remaining bits can be mathematically used to help reconstruct the correct signal.
2022-8-5
DreamWorks
Geebax Posted at 8-5 15:48
Hey, thanks for the explanation between yourself and Occams, I now understand what is actually going on, you guys explain it far better than any link with hard to understand tear down of the system., thank you, i will now stop calling it WiFi now that i understand it.
2022-8-5
Bigplumbs
Flight distance : 620164 ft
It is not WIFi. That is a term associated with the internet and routers it is the same think but not the correct name
Occusync is simply a radio transmission and receiving system transmitting on the 2.4 and 5.8 GHz frequencies and it hopps between the two based on certain factors
2022-8-5
fateofangel
Flight distance : 1397238 ft
Poland
DreamWorks Posted at 8-5 20:15
you can call it wifi, now try to find out what is electromagnetic wave and you ar at home
2022-8-6
Flormo2002
Flight distance : 12425794 ft
Bigplumbs Posted at 8-5 21:49
Yes, it's been explained
2022-8-6
Bashy
What is Lightbridge? Is it a lesser form of OC still using the 2.4 and 5.8
I ask because when I powered up my P4P inside (next to the laptop) when testing FCC mode, it knocked out the wifi to my laptop, I had to reboot the router to get it back.
2022-8-6
Bigplumbs
Flormo2002 Posted at 8-6 18:31
Yes I know I explained it
2022-8-6
Flormo2002
Bigplumbs Posted at 8-6 22:51
Not really. Occams and Geebax did. You just reiterated
2022-8-7
djiuser_zKR5HFX3a2EC
Flight distance : 474537 ft
Their OS system is basically just wifi 2.4 and 5.0 like your home wifi. The only difference from what I can tell is, it's dji automatic system, which it will automatically detect the best channel and hope between 2.4 and 5.0 to give you the best signal.
2023-6-24
Burt37
Flight distance : 4009 ft
MySky Posted at 2022-8-3 11:27
Well if that's the case, then I wonder why DJI has not released the firmware to update the RC Pro from O3 to O4...
2023-10-7
