Active Track 4K 50fps
1560 6 2022-8-3
UserOS
Flight distance : 82182 ft
Russia
please add 4k 50fps for active track
2022-8-3
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. I will take this as a suggestion of yours and will forward it to our designated team for attention. After the evaluation of the engineers, significant suggestions or requests will be implemented via the firmware update, app update, etc. For any updates, please stay tuned to the latest news on our DJI official website at www.dji.com. Thank you for your understanding and support.
2022-8-3
DowntownRDB
Flight distance : 1722 ft
+1 for adding 4k 50fps for active track.
2022-8-4
CPS
+1 for adding 4k 48/50/60fps and d-cinelike for active track, quick and mastershots...the name says PRO but it is not under these characteristics
2022-8-4
fateofangel
Flight distance : 1397238 ft
Poland
M3p will probably melt but +1
2022-8-4
HarleyFlyer
Flight distance : 1356178 ft
+1 for this also
2022-8-4
Willi33
Flight distance : 266913 ft
Hi,
I would be even happy, if Quickshots and Mastershots would be possible in 25 fps if higher rates are a problem for DJI. Many users in Europe use 25 or 50 fps, because in a 50 Hz region powered lights can cause flickers in the movie. DJI knows that problem and gives you the option to set the fps in videos also to 25 or 50 and in the camera menu you can set to 50 Hz to avoid flickers. But why are Quickshots and Mastershots limited to 30 fps?
In addition I agree with the original poster, that 4k 50 fps would be great.
Thanks and regards
Willi
2022-11-4
