badtuna Posted at 8-5 15:16
Hello Susan,
Everything worked well using assistant 2 on my PC. Thanks. However, I still don't quite understand why it could not update via wifi.
Thanks for your update. We are glad to see your problem is resolved.
And the following details may help you more with your problem, please check: DJI Mini 3 Pro is designed without a built-in fan, which can effectively reduce power consumption to make the flight time longer. The upgrade might fail due to overheating when it is turned on and stationary for a long time. You can update it via assistant 2 or use a fan to help cool down the aircraft when you meet this problem.
And if you have any more questions or need any support, you can also let us know. |
