Fly app does not work anymore (one plus 9 pro)
123456Next >
13858 210 2022-8-4
Messaris
Flight distance : 2067280 ft
Greece
Hi, suddenly yesterday I ve tried to launch the fly app on my phone (Ones plus 9 pro) which unfortunately i won't start, the weird thing is that it seems to work in the background.  Can someone help?
Regards
2022-8-4
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. Can you please try to uninstall and reinstall the DJI Fly app on your mobile device to see if the issue persists? In addition, kindly please send us a screenshot of the error message showing when you setup the app on your mobile device for us to check here on our end. Please keep us posted. Thank you.
2022-8-4
Kasekuchen
Hi,
i have the pixel 6 and have same problem. I tried to uninstall and reinstall even with power down of phone in between.
the problem encountered suddenly without any apparent updates. In the past it was just fine
Help needed
2022-8-4
Messaris
Greece
Hi I ve already done what you suggested.
The message said: the application "Dji Fly" Failed to start to many times. Do you want to restore it by clearing the history.
2022-8-4
Messaris
Greece
Kasekuchen Posted at 8-4 22:06
Hi,
Exactly the same
2022-8-4
Messaris
Greece
I ve tried to run older versions of Dji Fly 1.6.6 and 1.5.9 and the problem still persists
2022-8-4
djiuser_ILz1Z9ysIOWj
Messaris Posted at 8-4 22:14
The message said: the application "Dji Fly" Failed to start to many times. Do you want to restore it by clearing the history.[Image]
Exactly the Same here. Oneplus 8 pro Android 12.
2022-8-5
djiuser_9PduMDMyOPRN
Exactly the same also for me > One plus 9 pro with android 12.  I've tryed all the version of App (1.4.8 -1.4.12 - 1.5.1) and the last 1.6.9
Without any known update of the os
2022-8-6
djiuser_oQ1Kp5qTzksx
Same thing in my pixel 6 pro.. oddly it worked yesterday.. Now it just flashes the app screen and closes right away.  I uninstalled it, reinstalled the APK from DJI 's website, rebooted, cleared app cache.. Nada.
2022-8-6
Ms Ivy
Flight distance : 20358422 ft
djiuser_oQ1Kp5qTzksx Posted at 8-6 06:35
same thing with me
I posted a thread on it myself https://forum.dji.com/forum.php? ... D565%26typeid%3D565
2022-8-6
djiuser_Vsr4O9z5rjKV
I am also having the same issue with my OnePlus 8t since yesterday. The following msg pop up..
2022-8-6
djiuser_svS1Hmnnvrku
Got the same issue now.. was working yesterday and now today it just close as soon as I open it. I did nothing since last time it worked....
2022-8-6
I have same issue. Was working fine yesterday and today it crashes for no reason.  I did everything tech 101, reinstall delete cache, reboot... Nothing !!!
2022-8-6
Messaris
Greece
Today I did a factory reset to my phone, I download the app and It was working perfectly until I connected it to the controller. As soon it was connected it started again  .So something trigger it when it connects  either with the controller   or the plane.
2022-8-6
Ms Ivy
Just a heads up if the User is aware of the risk of DJI not honoring the warranty of your new drone for using a 3rd party fly app.   the FAA "Aloft Kittyhawk" App found in the google play-store will work on the DJI Mini2 with a fairly good range of about 5 to 6k and it will load and work on any android 12 phone including Motorola phones with android 12. 64 byte.
this is just a alternative for flying your mini 2 until DJI decides to fix the Fly-app so we can use it. as it is now my mini2 is just a desk top paper weight  with the fly-app broke
2022-8-6
djiuser_PiOmqps5bcar
Flight distance : 5493753 ft
Messaris Posted at 8-6 08:43
I have the same problem with OnePlus 8, android 12. And mavic 3.
I did everything possible. I just need to format the cell phone, which I don't want to do... and I had a flight planned today and I couldn't do it... I'll try another phone and it counts.
2022-8-6
djiuser_t8ymOA6TEUol
Flight distance : 7802 ft
Mexico
Hello, I have the same issue, same phone, with a mini 3 pro. I tried uninstalling and with older versions of the apps, but got the same result.
2022-8-6
djiuser_t8ymOA6TEUol Posted at 8-6 12:48
I hope that the people of Dji give us the arguments soon.  And a solution other than formatting and something else...
2022-8-6
Dji mimo doesn't work for me either.  looks like it's any Dji app.
2022-8-6
Messaris
Greece
djiuser_PiOmqps5bcar Posted at 8-6 13:40
I did recover to factory settings my phone but it didn t help. As soon you connect to the plane it starts again.
2022-8-6
djiuser_QE18okTClSUQ
Flight distance : 96407 ft
Bonjour même problème sur Oneplus 8 pro plantage au lancement et impossible de revenir sur une ancienne version. Ça tombe mal sur son lieu de vacances
2022-8-7
djiuser_6A1uXdAVmukG
Dominican Republic
I've also had that problem with the fly app on my OnePlus 9 pro. I did everything possible, except for the factory reset. But I believe that the factory reset won't do much. When I open the app, it shows the white screen and then closes quickly. Then I get the message shown attached.
2022-8-7
DJI Natalia
Dear all:
We are sorry for the inconvenience caused.
Please don't worry, our relevant team is checking this problem.
If you are urgent about this issue, you can also ask me for more help. (You can contact me via PM)
Besides, if you need any support, you can contact us anytime here.
2022-8-8
DJI Natalia Posted at 8-8 01:08
Dear all:
I hope you have an answer with solutions as soon as possible.
2022-8-8
You can see what happens in this video.
another thing that I realized is that the permissions are disabled at all times since less than a minute ago I had authorized the location and storage.
https://drive.google.com/file/d/1M9qPcEXv1L3mwoQJ8cEIP67ukFejCeuo/view?usp=drivesdk
2022-8-8
Messaris
Greece
I had a test flight.... everything seems to be working smoothly again!! Thanx for the quick response!!!
2022-8-8
Messaris Posted at 8-8 03:14
what did you do to make it work again?
2022-8-8
Messaris
Greece
djiuser_PiOmqps5bcar Posted at 8-8 04:05
Check your Pm
2022-8-8
How did you make it work?
2022-8-8
I have tried it with a Samsung Galaxy 9 edge and my account and it already worked perfectly.  Could it be that I have a truncated android log file?  or something like that?
2022-8-8
Messaris
Greece
Check your Pm
2022-8-8
djiuser_emo7EMe287J6
Slovakia
Dear all:
send me the test file. thx
2022-8-8
DJI Natalia
djiuser_emo7EMe287J6 Posted at 8-8 06:47
Hi, there. We have sent you a PM, could you please check?
2022-8-8
DJI Natalia
Hi, there. We have checked your PM and found your problem is resolved. We are glad to see this.
Besides, if there is anything else that we can help with, please let us know.
2022-8-8
DJI Natalia
djiuser_PiOmqps5bcar Posted at 8-8 02:53
Update:
Please don't worry, we are checking this problem already.
You can also check your PM to get more help about this issue. Thank you.
2022-8-8
djiuser_1Wcj8sJyCyaM
Flight distance : 58383 ft
DJI Natalia Posted at 8-8 18:19
Update:
Please send me an PM to resolve the issued. Have same Problems with my OnePlus 8 Pro
2022-8-8
djiuser_9gVqRjdTtZH1
Dear all:
Hi I am having the same issue as the other users with my Pixel 6. The app won't open but seems to run in the background. Uninstall and reinstall has not fixed it. Can you send me the fix in a PM please.
2022-8-8
fansb97e1cd6
Flight distance : 87267 ft
Same here with pixel 4a5g , can you pm me?
2022-8-8
MattHutch
Hi, I am experiencing the same issue, are you please able to PM the solution to fix this issue. Thanks
2022-8-8
DronWWO
Poland
Same problem with OnePlus 9 Pro. Please send PM with solution.
2022-8-9
123456Next >
