Transmission and range issues related to hidden geo-fencing?
1506 16 2022-8-5
zzjollygreenzz
Really interesting transmission mode results guys!  I tried 10-15 different spots today, see the map image, booting the RC Controller up and then the drone and then checking to see which transmission mode the controller allows me to fly in.
Mode A is what I would call normal, unlimited mode, you can select Dual band, 2.4hz, 5.8Ghz or Auto/manual and if you choose manual, you can select the exact channel you want in either 2.4ghz or 5.8ghz mode.  This mode will probably let you fly long range, 500m-4000m
Mode B is what I would call severely limited, low power / low range mode, you're probably only going to get to 500m range.  You can't select anything, it just shows you the 2.4ghz spectrum.
It came up in Mode A at my house, a couple parks nearby, the boat ramp and another park on the beach.  It came up in mode B all along the beach and all along another beach park.  I tested each location multiple times, so these aren't flukes, it consistently comes up in each mode the same, depending on the geo-location.
This is probably why the range issues people have are so inconsistent.  Some people are in an area where it comes up in mode A and some people are in an area where it comes up in mode B.  Then you have interference around, in which ever mode location you are in.
Map
Map
2022-8-5
djiuser_VjWyE2nrKJGV
Great info and I think you hit it on the head. If true, which I think it is, it’s super lame that DJI isn’t documenting and communicating these programmed constraints and expected impact. I bet it’s also somewhat buggy and inconsistent.
2022-8-5
Bashy
Flight distance : 2354357 ft
A = FCC and B = CE modes thats why youre going further in A, you're right about low power for sure, as to the reason, beats me. It might be something to do with allowing enough time for GPS loc before doing X, someone else with more info on this issue should be able to help here, but you need to bring it up with support@dji.com I don't think it has anything to do with the geo fence though, because you managed A actually closest to the geo fenced point...
2022-8-5
DJI Stephen
Hello there zzjollygreenzz. Good day and thank you for sharing these interesting information with us here at DJI Forum. Again, thank you for your support and keep flying.
2022-8-5
fly.overflying
I have experienced this issue, the only difference is that I am locked on the CE mode all times. I my situation the aircraft has already been replaced by DJI and now I am waiting for a RCN-1 controller to arrive for testing sent by DJI, Let see what is gonna happen when I connect the aircraft with this controller if I will still get CE mode only or if I will get the FCC outright, that should determine if this is RC related which I am inclined to believe at this point.
2022-8-5
Bigplumbs
Flight distance : 620164 ft
DJI Stephen Posted at 8-5 20:48
Are you not going to show this to the designated department
2022-8-5
Bigplumbs
This sort of thing is another good reason not to update your drone if it is OK. DJI will sneak stuff in and not tell you
2022-8-5
zzjollygreenzz
Bigplumbs Posted at 8-5 21:40
A guy on Facebook is saying that the beach/sand might generate a magnetic field causing RF interference.  I'm not sure this is the issue, because one place I tested was about 40meters from the beach in a grassy field and it came up in mode B, another place was on an elevated grassy hill away from the beach and it came up in mode B.
I'll try and think of some more tests to do, I'll also try the N1 controller tomorrow as well, my friend has a mini 2 controller we can test with the mini 3 pro
2022-8-5
fly.overflying
Is there a way to step back a firmware version?
2022-8-5
fans5d3e3440
Flight distance : 4964 ft
fly.overflying Posted at 8-5 22:18
Yes, use DJI Assistant 2 (Consumer Drone series).
2022-8-5
fly.overflying
zzjollygreenzz Posted at 8-5 22:17
I wish the proximity from the beach could be the cause but in my case I am far away from the ocean. I should receive a RCN 1 from DJI support tomorrow as well to test and try to isolate the issue to the controller. Below is my video I posted yesterday.
https://www.youtube.com/watch?v=eKcBkLge9Vc
2022-8-5
DowntownRDB
Flight distance : 1722 ft
fly.overflying Posted at 8-5 22:54
Your video definitely indicates you were locked in CE mode.  Will be interesting to see if you can get FCC mode on the inbound RC N1 controller.
2022-8-6
Pastime
Flight distance : 3395469 ft
Hmmmm,a guy on Facebook said this. Never heard of beach sand causing a magnetic field.
Myself along with who knows how many others almost always fly over a beach with sand to get to the water.Never ever had any signal issues at all.
2022-8-6
zzjollygreenzz
Here you go, got a screen grab!  I took the drone to an area where it comes up in mode B, restricted mode.  I powered on the RC Controller and held it directly on top of the mini 3 pro.  I then powered up the mini 3 pro.  This makes it take a longer time to get GPS lock.  The drone boots up and with no home point and 0 satellites found, it is in normal transmission mode A, you can select dual-band, 5.8ghz, 2.4ghz or manual and select whatever channel you want.  After it gets gps lock and a home point, it switches into restricted transmission mode B with no ability to pick any of the above options like I was able to do when it was in normal mode A.
2022-8-6
fly.overflying
zzjollygreenzz Posted at 8-6 12:06
https://youtu.be/dmSO45VD0PY?t=33
Thank you for the video, another evidence for DJI to put their act together and test their products properly before launching.
Yeah, I know they do not care about anything else oher than $$$$ (sales)
2022-8-6
zzjollygreenzz
Just tested with the RC232/RCN1, the RC231 is the same as RCN1
When the mini 3 pro powers up on the N1, it is in normal transmission mode where you can select dual band, 5.8ghz, 2.4ghz, etc... I immediately tested my RC controller, it comes up in the restricted transmission mode, dual-band, 5.8ghz and 2.4ghz are not options, it just shows the 2.4 ghz spectrum and no ability to select any transmission options.
I did flight tests as well.  Flying the N1, not a single bar was lost out to 1500m, flying in the 1m to 20m altitude range.  The whole time the transmission tab looked normal and it had selected 5.8ghz to use for the band
Flying with the RC controller, bars started dropping at 500m, down to 1-2 bars in the 700-900m range.  I didn't fly past 1000m.  Today it flew a little further than a few days ago.  The transmission tab always stayed in the restricted mode, only showing 2.4ghz spectrum with no options available.
Something is definitely different between the RC and N1
2022-8-7
fly.overflying
zzjollygreenzz Posted at 8-7 10:40
There is a variance that prevents the RC to connect on the proper country frequency, also there is another variance forcing the RC to connect to another country frequency instead of connecting to the correct one.
Now it is a matter of long time for DJI to figure how to fix this up.
2022-8-7
