Labroides
Flight distance : 9991457 ft
dreamtuner Posted at 8-6 21:33
That's what I knew as well. Since it is not the case for video I guess cropping or applying some lens correction profile could be a workaround for images. Thanks!
That's not a fault and nothing you can correct..
It's a feature of very wideangle lenses.
Your verticals are leaning in towards the centre because the lens was tilted downwards from perfectly horizontal.
If you tilt the camera up, verticals will appear to be falling outwards.
The keep verticals vertical, you need to keep the lens at 0° to the horizon. |
