DJI Mimo no longer supports Android 7/iOS 11 or earlier
7495 20 2022-8-7
DJI Support
Flight distance : 2408 ft
The next version of DJI Mimo will no longer support devices running Android 7/iOS 11 or earlier versions. Please update to Android 8+/iOS 12+ to continue to benefit from regular feature updates, performance improvements, and bug fixes. If you want to download the app for devices that run Android 7/iOS 11 or earlier versions, download it from Download Center on the DJI official website. Thank you for your understanding and support.
Download link: https://www.dji.com/downloads/djiapp/dji-mimo
2022-8-7
Frontliner 2020
Philippines
thank you for these info...
2022-8-7
chris1269
Die aktuelle DJI MimoApp wird leider auch nicht mehr von Android 12 und meinem Google Pixel 6 Pro unterstützt :-(
2022-8-8
djiuser_KksDvKOnWaEk
Turkey
chris1269 Posted at 8-8 00:34
Hi chris schön jemandem mit einem pixel 6 zu sehen ich habe Probleme mit der Kalibrierung. Handy wird immer neu gestartet. Ist es bei dir auch so ? Wäre super wenn du mir weiterhelfen könntest.
2022-8-8
Turkey
I had android 12 the New App didnt Work. I have now Android 13 beta its the Same. Always Crash at beginning
2022-8-8
djiuser_2mIQPd22N3lc
And for LightCut App and DJI Fly ? Because i got this 3 App and they didn't work since the update
2022-8-9
djiuser_qzjP7A4l02kc
Mimo app not work on my Samsung S22 ultra android 12 ,I uninstall the old mimo app and reinstall the new mimo from dji official site still not work
2022-8-9
djiuser_kiQmXZupyUlv
India
Hello team, I still am having the same issue with the Mimo App, I've tried uninstalling and reinstalling the app.. still the same issue persists.
Please suggest
2022-8-10
Bob Brown
Flight distance : 4209662 ft
or apparently any other version for that matter. Android 12 is not working as of 8-10-2022. DJI Fly and Mimo broken.
2022-8-10
djiuser_u2K7STzScjkU
Bob Brown Posted at 8-10 19:33
Same here. Both apps, DJI Mimo and DJI fly suddenly did not start anymore on Samsung Galaxy S21 Ultra  with android 12, One UI 4.1, google play system update from 1st July and Security Patch from 1st of august. On another Smartphone, Galaxy A51 with Android 12, One UI 4.1, google play system update from 1st may and Security Patch from 1st april both apps run like a charm. Maybe this information helps to fix the problem.
2022-8-10
djiuser_SU3LHBX3qroi
Flight distance : 44242 ft
South Africa
This is strange as even with a better version of what you are referring to i am still not able to use mimo. To the point that i am now returning my om5 as i am not able to make use of it. Please advice as i am using a Samsung S22+
2022-8-11
djiuser_hoHkrHdxv8L9
Philippines
djiuser_SU3LHBX3qroi Posted at 8-11 06:11
My DJI mimo is no longer working. Please help me.
2022-8-12
djiuser_x4zNMQa36i5r
Colombia
Hola dji mimo me esta fallando con un samsung s20 fe necesito ayuda
2022-8-12
Turkey
Google pixel 6 pro dji mimo App Always Crash. I download it. Open from Explorer Same. Download from dji Website. I have android 12. Can any1 Help me pls
2022-8-12
djiuser_M65cBz4uN4GL
Hungary
Hi!  DJI Mimo app not working on Android12 Samsung Galaxy Note 20 Ultra.  After installation, it crashes when you click on the icon.
2022-8-13
djiuser_zquR0BrAHKDu
Flight distance : 57608 ft
Puerto Rico
I have downloaded the app again and I still have the problem on Pixel 6 Pro which is version 1.7.24 and I still have the problem that it does not open the app.  I count on you for the solution.  Thank you
2022-8-13
djiuser_gj0XQpvEWulI
Colombia
Yo también tengo un S21 ultra ya descargue la última actualización y no funciona necesite utilizar mi DJI OSMO 4 y fue inútil alguien puede ayudarnos o decir algo me parece un juego sucio pues el producto no es nada económico para que lo hagan inútil en tan corto tiempo
2022-8-18
Fraagles
Poland
hello everyone! Can someone confirm whether dji works without a problem on pixel 6 on android 13? I want to finally update android 12 to 13, but I'm afraid I won't connect to the cameras.
2022-10-24
Fred Fred Fred
Flight distance : 4512966 ft
Thanks for the info Dji.
2022-10-25
Fresh!
" The next version of DJI Mimo will no longer support devices running Android 7/iOS 11 or earlier versions" - Can you please specify which is the last version that supports Android 7, thank you.
4-17 13:18
DJI Wanda
Fresh! Posted at 4-17 13:18
Hello, there. From V1.7.24, DJI Mimo no longer supports Android 7/iOS 11 or earlier versions. That is, the last version support Andriod 7 is V1.7.20.
4-17 19:19
