RS3 Pro Firmware Prompt
1912 7 2022-8-8
rotor-head.com
Flight distance : 10823 ft
On my RS3 Pro, I updated all of the firmware and every time I power it on, it says "Inconsistant Firmware".  and wants me to update (even when I don't change anything on it (batteries, etc) or cancel.  I've updated it again and again, but the promp is there every startup.  When I turn on my phone and launch the Ronin App, it whows 80% firware updated.  Any ideas on how to fix it?
I can use it normally, but it's just kind of a drag to cancell it every time I turn it on.
Thanks
RS3 Pro
RS3 Pro
2022-8-8
rotor-head.com
UPDATE.  Still does it except when I have a camera trigger remote plugged in..
2022-8-15
kmoreau893
I am having this same issue and my Lidar autofocus isn't working. I suspect it may be the focus motor but I don't. know how to update it. Does DJI support look at these threads beaus nobody has replied to you for several days.
2022-8-19
rotor-head.com
I don't think it's monitored very well.  I seem to rarely get any responses.  Bummer.
2022-8-19
johannesh
Sweden
same problem here, even after the latest update and after manually updating my lidar sensor in my computer through the dji assistant 2 app.
2022-10-24
ValleyForge
Flight distance : 24754 ft
johannesh Posted at 10-24 04:24
Updated both the LiDAR and the Ronin via the USB cable? If so - that's bloody annoying.
Whilst FOTA (firmware over-the-air) is convenient, it is so easy to brick things. If I can, I always do it via a cable or memory card.
2022-10-24
johannesh
Sweden
ValleyForge Posted at 10-24 16:43
Hi! No, only the Lidar. I'm going to try to do an cable update of the ronin and see if that changes anything. The ronin still works fine, but I wonder what firmware is inconsistent.
2022-10-26
ValleyForge
johannesh Posted at 10-26 01:54
I recently had to replace my Focus Motor (2022) under warranty. When I powered it up on the gimbal I got an incompatible firmware prompt.
Went through with it and, yes the motor's LED flashed a few times and is all good now.
2022-12-20
