Uploading Fruit Tree Coordinates using shp or kml files?
3838 31 2022-8-8
sneakyMoose
New Zealand
Hi. Does anyone know if its possible to upload the coordinates from something like QGIS of fruit trees to the Agras Management System/remote control via an SD card?
Thanks
2022-8-8
DJI Natalia
Hi, there. Please note that T series machines can achieve this, but MG series can't.
Besides, if there is anything else that we can help with, please let us know.
Thank you.
2022-9-1
sneakyMoose
New Zealand
DJI Natalia Posted at 9-1 01:12
Thank you.
Can you tell me how the T series drones can do it?
2022-9-17
DJI Natalia
Hi, there.
Please check this link: https://hk-cc-knowledge-prod.oss ... %20Introduction.pdf
And the following details are for your reference:
1. Overview of file composition
A Shapefile refers to a method for file storage and is composed of several files.
A Shapefile has 3 essential files (postfix: .shp, .shx, .dbf). It can constitute a group of complete geographic data and 8 optional files to enhance the expression of spatial data.
2. The DJI Agras app supports the importing of Shapefiles with some requirements for the imported file formats (as shown below):
shp file: Only supports polygon. In a polygon, clockwise are the edges of the plot, and counterclockwise is the plot obstacle. For unsupported types, the import is ignored.
shx file: This file is ignored. Regardless of whether this file exists or not, it will not affect the import result.
dbf file: The dbf file includes the configuration information of the imported plot. If there is no corresponding configuration information, the default value will be used.
This means that: To be imported in the DJI Agras app, the file should have a shp file and dbf file.
3. File storage path in the remote controller’s microSD card:
.../DJI/ShapeFile
Thank you for your support.
2022-9-19
djiuser_ZV5vJUaivZU8
DJI Natalia Posted at 2022-9-19 00:48
Hi, there.
Hi
The link does not open .
can you repost the updated link.
tnks
2023-1-2
DJI Natalia
djiuser_ZV5vJUaivZU8 Posted at 1-2 22:09
Hi
Hi, there.
Could you please try clicking the link directly and see if you can open this file?
Thank you in advance.
2023-1-3
DJI Natalia Posted at 1-3 00:35
Hi, there.
it says that  "You have no right to access this object because of bucket acl."
2023-1-3
DJI Natalia
djiuser_ZV5vJUaivZU8 Posted at 1-3 07:21
Thanks for your update.
We will send you the PDF version via PM asap, could you please have a look?
Thank you in advance for your patience.
2023-1-5
Hi, again ,
i've tried to load shapeFile to mg-1p remote.
it shows the files on the menu, but when i select one of them, it crashes and will stuck on loading page.
system version: 02.03.0404
these are the files that i'm trying to open:
espad.zip
if it's possible for you, please check them and let me know that what's  wrong with the files.
Thanks in advance
2023-1-14
files:
https://drive.google.com/file/d/1RgFTqLq8rhVPzq8f0nIB9i1WVu7ygE7e/view?usp=sharing
2023-1-14
DJI Natalia
Hi, there.
We noticed that you are using the MG-1P controller, but the related version is the T20 version (02.03.0404). When the MG1P controller is upgraded to the T20 version to use, the APP may crash sometimes.
It is recommended that you upgrade the corresponding controller version:
Aircraft Firmware: V02.01.0221
Controller firmware: V02.01.0224
We have also sent you an account to help you upgrade, could you please check it?
Thank you.
2023-1-16
EduardoCruz
Brazil
Hi, there.
Hi Natalia,
Could you share the pdf file with me?
Thanks
2023-2-11
DJI Natalia
EduardoCruz Posted at 2-11 12:42
Hi Natalia,
Thanks
Hi, there. We will send it to you via PM asap.
Thank you.
2023-2-11
Egutierrez3
Hi, there.
Hi, could I get the link too?
One more question, is it possible to upload kml or polyline files to a RM500 controller? The one used for T20 drone.
Thanks
2023-3-7
DJI Natalia
Egutierrez3 Posted at 3-7 10:16
Hi, there.
Thanks for your inquiry.
We will send you the link via PM, please check it.
And for your problem, please note that it is not supported to upload kml or polyline files to RM500 controller.
Thanks for your understanding.
2023-3-9
felipeuchoa
Brazil
Hi, there.
Hi,
Can you tell me how to create a counterclockwise polygon in Qgis? When creating the polygon and exporting it to the remote control, only the edges of the graphic appear.
2023-4-9
patiam
Flight distance : 1118740 ft
Why is the solution to PM a file to individual users rather than to post it for all who need it?
2023-4-9
DJI Natalia
felipeuchoa Posted at 4-9 16:04
Hi,
Hi, there. For this problem, you could try creating a hollow polygon and you'll be able to see. (The definition of a hollow in a polygon is that the vertices are generated in counterclockwise order.)
Hope this helps and if you meet any problems, please feel free to let us know.
2023-4-11
DJI Natalia
patiam Posted at 4-9 17:15
Hi, there. Because some users can not open this file directly, if you meet this problem, you can try to open this file on #4 and see if it works, you can also click this link here: https://hk-cc-knowledge-prod.oss ... %20Introduction.pdf
2023-4-11
Drone_Agras
Flight distance : 1383983 ft
DJI Natalia Posted at 4-11 01:46
Hi, there. Because some users can not open this file directly, if you meet this problem, you can try to open this file on #4 and see if it works, you can also click this link here: https://hk-cc-knowledge-prod.oss-cn-hongkong.aliyuncs.com/Spot%20Spraying%20Introduction.pdf
Hi Natalia, can you share with me the link?, i can't see it. Thanks!
2023-4-11
OTAVIO.SILVA
Brazil
Hi Natalia!
Can you send me the file as well? I've tried and got Access Denied through all links posted before.
Thanks
2023-4-11
DJI Natalia
Drone_Agras Posted at 4-11 06:05
Hi, there. Please click this link and see if it helps: https://pan-sec.djicorp.com/s/ZD5KNK9Kma3BLd6
2023-4-11
DJI Natalia
OTAVIO.SILVA Posted at 4-11 10:11
Hi Natalia!
Hi, there. Could you please try to click this link and check it again: https://pan-sec.djicorp.com/s/ZD5KNK9Kma3BLd6
Please let us know if you meet any problems.
2023-4-11
Drone_Agras
DJI Natalia Posted at 4-11 23:38
Hi, thanks you so much for your answer!
2023-5-2
DJI Natalia
Drone_Agras Posted at 5-2 10:34
You are welcome.
2023-5-2
djiuser_xjj64ls3Y50G
Hi Natalia, could you please send me that file as well? None of the links are working.
2023-9-21
LV_Forestry
Flight distance : 4726654 ft
Latvia
djiuser_xjj64ls3Y50G Posted at 9-21 08:26
We haven't seen Natalia here for a while.
Our new mom is Wanda.
She will most likely respond to your request. Be patient.
2023-9-21
FIRETAIL
Flight distance : 275538 ft
I'd be keen for this pdf too. I've got a polygon workflow for boundaries but interested to understand if points can also be applied.
2023-9-24
fans2f003e46
Flight distance : 83512477 ft
I'd be interested in a copy too please.
2023-9-25
FIRETAIL
Hi,
Hey felipeuchoa, did you ever get an answer on this?
2023-10-30
djiuser_aelzyJwimRyw
Brazil
The link has expired, can you copy and paste the main text here?
1-3 11:30
djiuser_5YPYDCXVwtjI
Dji can I also ease be sent this PDF document regarding Shape file specifications? Our company run a flight of 12  T16s that we use for Spreading operations uploading area. Definitions using shape files is mandatory to our operation. and we have found it very frustrating. When certain shape files don’t work, we have not been able to find information on what the specific issue is with these particular files. also, could you please provide the best and most current firmware for the T16 with MG—P1 controller in 01-2024?
1-28 02:26
