Sean-bumble-bee
Flight distance : 15997 ft
vkondra Posted at 8-9 10:26
It is matter of taste, what you like more - removing SD card or plugging USB. Both options has pros and cons. I am not trying to argue what is better. My point USB option may be easily improved and made usable. After all, when you remove SD card, you insert it into some type of USB adapter, unless your computer has this adapter built-in. If drone detects USB data connection, there's no point to turn on power consuming parts, it may act as flash drive with minimal power consumption. Therefore ventilation will not be needed.
You have a point about reducing power consumption.
From memory, when down loading DAT's from either a Phantom 3 or perhaps a M2P, but probably the Phantom, the download takes a LLLoooNNNggg time, yet the battery consumption is minimal. As if the drone switches off unneeded parts. Whether or not DJI could modify the boot behaviour I have no idea but the P3 certainly goes through a full boot sequence before it it possible to use the App to switch it into the data transfer mode. That I remember the M2P goes through a full boot process too though the data transfer is triggered by the running Assistant 2
But if the Mini 3 is connected to the computer without the drone being switched on doesn't that initiate the battery charging mode where the drone can NOT be switched on? It does with the Mavic Mini and Mini 2.
But I still have concerns about ventialation etc. etc. and point a fan at the P3 and M2P.
