Kaku Ito
![](https://forum44.djicdn.com/data/attachment/common/c2/common_12_usergroup_icon.png) lvl.3
Japan
Hello everyone,
How are you going doing with LiDAR Range Finder?
After working with it for several weeks, I found these things are important.
First of all, the back focus of the camera and the lens is very important. In order for close and far focus to work, right back focus adjustment is needed even for the prime lenses.
If the back focus is off, then when you do 1 meter and 4 meter calibration, the 4 meter focus will go off after LiDAR figures out the focus range. I ajusted the backfocus of my RED Weapon Helium and my Sigma Primes, it works great.
Also, I ofset the vertical angle to make the pointing of the LiDAR to the object. That will make LiDAR to follow center of the object better.
Make sure you connect the LiDAR to the bottom of the USB-C port of the RS3 Pro. Only the bottom port will give you the picture to RS3 Pro.
Make sure you do the 1 meter/4 meter calibration in open space.
I have extra focus wheel (Ronin-S focus wheel) connected on my DJI Tethered Handle, so I have two wheels (actually three wheels including the RS3 Pro's itself but it works the same on the tethered handle's built in wheel). I use the built in wheel as controlling "Roll" to give more expression by assigning in the Dial section, then the extra wheel becomes the focus control of the motor. If you leave it as defualt then built in wheel control the focus. When you do 1m/4m calibration, RS3 Pro swtches back the built in wheel to control the focus, and RS3 Pro does that automatically, so don't get fooled by that. I hope DJI be able to add parameters to set both built in and added focus wheel independantly in the future so that we don't have to assume how RS3 Pro is acting.
Still zoom lens is prolematic since the back focus of each focal length does not have correct back focus. If back focus of the zoom lens is good like the real cinema or broadcast zoom lens, then what I would do is that decide which focal lenth you would use, if 24-105mm then something like 24, 35 and 50mm, then calibrate at that focal length with the 1m/4m calibration. However, it won't give you precise auto focus especially at the longer focal point (the close focus would work well relatively). I might need to work on these matter more, so give me suggestions if you have the solution.
These are the things I found out from working with it. |
