Mavic 3 Battery will not wake up
2681 6 2022-8-10
MM M3 Cine
I have 6 Mavic 3 batteries that I rotate usage with.  They've all been great so far except for the last time when I wanted to charge them.  Four of them were awake and two were not.  So I placed one of the hibernating batteries into the Mavic 3 Cine and connected the USB cable and it woke up in a couple of seconds and charged up fine.  The second hibernating battery would not wake up or charge at all.  Has anyone else experienced this?  Any info on how to wake this one battery up would be greatly appreciated.  Thanks
2022-8-10
DJI Paladin
Flight distance : 318 ft
HI there. Thank you for reaching out and we're deeply sorry for the trouble that this has caused. Could you please try to leave the said battery on the charger alone for approximately 2-3 hours and check if the issue persists? In addition, may I please ask when did you purchase the package? Please keep us posted. Thank you.
2022-8-10
MM M3 Cine
DJI Paladin Posted at 8-10 18:11
I put the battery in the M3 and plugged in the USB for more than 5 hours.  It didn't do anything.
I purchased the drone December 2021.  I purchased the problem battery April 2022.
2022-8-11
bjr981s
Flight distance : 139698 ft
How far down are you discharging the batteries?
2022-8-11
MM M3 Cine
bjr981s Posted at 8-11 10:43
When I fly, I use the whole battery until it's nearly empty... -Is that what you mean?
2022-8-11
DJI Paladin
MM M3 Cine Posted at 8-11 02:04
Thank you for keeping us posted. In this case, we strongly recommend coordinating this with our team at  https://www.dji.com/support for us to process a ticket with regards to your battery. Again, we're sorry for the trouble. Thank you for your understanding and support.
2022-8-16
bjr981s
MM M3 Cine Posted at 8-11 17:54
Yes that is what I meant. Flying the battery down to minimum reduces the number of times the battery will cycle charge. Do not go below 20% battery.
2022-8-19
