FPV Motion Controller (brand new) will not charge
4442 13 2022-8-12
tmexx
Flight distance : 23 ft
Plugged it into the FPV Power brick with supplied cables and only the first indicator flashes (rapidly). Left for 8 hours and no signs of charging.
Any way to reset so the controller can get a charge and then hopefully be set up?
Thanks in advance for any advice.
Tmexx
2022-8-12
DJI Stephen
Hello there Tmexx. I am sorry for the trouble this has caused and thank you for reaching out. Kindly please try using a different charger with a specification of 5V, 1 for us to be bale to see if the issue will persist. Thank you.
2022-8-12
djiuser_Xfh4pTebkEKW
DJI Stephen Posted at 8-12 19:58
[view_image]
hi, i have the same problem. reveived dji avata yesterday. all other batteries charge fine but motion controller does not charge. tries many difference power blocks for usb-c without luck. what can i do next?
2022-9-1
djiuser_839qy6FxyIbA
Flight distance : 219373 ft
Bulgaria
I also have the same issue, tried all kinds of charges and cables
2022-9-2
Iczeman
Flight distance : 8367569 ft
Czechia
Hi,
try more chargers/cables it will charge I'm sure, as in my case two out of ten cables/chargers are working...
2022-9-2
fans47cb5ee7
I’m having the same issue.  Batteries for the goggles and drone charged fine.  Controller won’t charge.  I’ve tried multiple cables and chargers.
2022-9-2
fansd60646f6
Israel
Yep. Same issue here. Support told me they would talk to their engineers....
But fixed by using a USB-A to USB-C cable...
2022-9-2
fans5ad140ae
Ah yes! Usb A to type C cable has fixed the issue for me too! Thanks for sharing your solution, I can now fly my new drone. Shame I had to purchase a second controller before I read this thread. I had tried multiple other cables and chargers none were working but they were all usb c chargers
2022-9-2
clean
I had this problem. Nothing would charge it. I plugged in into my microsoft surface chord (it has a usb port on side) it worked. ??? This wont help most but if you got a surface the adapter will charge the motion controller
2022-9-4
Dave In NH
Flight distance : 13436247 ft
My motion controller will not charge with the supplied cables. I have multiple USB C cables at home, and I was able to find a couple that work. I've been able to get out and fly, but this is not acceptable.
2022-9-15
Iamnotacowboy
I’m also in the same boat. I’ve used all of the included cables and provided my own. Spent an hour just cycling through cable combinations hoping to find one that worked. I failed. I left it overnight with a 100% functional combination that worked with others, but still no additional charge. Recommendations?
***I hope I’m in the right place. The issues are with a brand new Avata.
2022-9-16
djiuser_sSNlz7sviT8t
Flight distance : 29281 ft
The problem is the charging block. The plug you put your cable in. I had the same problem and nearly cried. But changed the block and it started blinking. All ok now.
2022-10-30
djiuser_CvnanuMv1LSl
fansd60646f6 Posted at 2022-9-2 04:43
Great, that worked. Thanks
2023-7-9
CireinTexas
Flight distance : 5786001 ft
The MC and V2 batteries will not charge with high power cables.  Use everyday cables and it should work.  I learned this by purchasing high watt cables that would not charge my  smaller batteries.
2023-8-10
