M300RTK flight altitude and terrain follow
6031 5 2022-8-13
UAV8-Mick
Hi, I am new to flying the M300RTK and came across a few anomilies I was unable to resolve...if anyone has any insight I would be most grateful.
Using only the DJI Pilot app on the smart controller and the D-RTK base station I was only "allowed" to set a flight altitude of 40ft as the minimum, using the Zenmuse P1 sensor this gives roughly a 0.15cm GSD for an ortho mission. A project I am working on is wanting to fly at only 25ft to attain 0.10cm GSD. Is there a reason I cannot change this value below 40ft? The same question exists in terrain follow mode as it seems restricted to 82.1ft, is there a reason for this or something I am missing to change this value?
On the terrain follow mode I have another question, after uploading a Digital Surface Model and loading it into the mission plan all seemed to make sense, the aircraft was going to fly 82.1ft above the DSM derived data, the mission altitude display showed that it would fly DSM+82.1ft, however, on launching the mission the M300 flew 130ft higher than was anticipated, but followed the terrain as expected, so at DSM+212.1ft.
I have been reading about ellipsoidal height vs gps derived but 130ft seems excessive in my mind but it is not a strong subject for me yet.
Any suggestions??
Many thanks.
2022-8-13
Vermesser
To start with, check which coordinate system your DSM has. Most important, what is the refernce surface for the Z-axes.
2022-8-21
eschreuder
Flight distance : 476404 ft
Is there any update to the terrain following? I work for a geospatial firm and confirmed the correct geoid vs ellipsoid of what I'm trying to import, but there are still issues. If I follow the DSM on the smart controller, the drone wants to fly ~100ft above the planned "Terrain Follow Height". What's interesting is that if I turn terrain follow off, the flight lines change minimally. When executing the non-terrain following flight, the planned overlap and GSD are accurate to what is actually collected (tested and proven), which means when I do execute the terrain-follow mode enabled, the dataset has a lower resolution and less overlap than what was planned (tested and confirmed - because it's obviously flying too high). Essentially, when following terrain, the drone wants to fly higher than it should, but then doesn't account for appropriate GSD or overlap.
2022-10-20
djiuser_leGPDcjqDZxa
New Zealand
I have the same issue. Our RTK base connected to the M300 is transmitting in a local geoid which is 10m different to WGS84 and when we have terrain follow on and the terrain follow height set to 100m the drone will fly at 90m rather than the 100m. If we turn the terrain follow off it will work at the 100m as set but you lose the terrain follow ability which is not what you want in undulating terrain. Is there a fix for pilot app to correct for the geoid vs WGS84 so terrain follow is accurate?
2024-6-18
LV_Forestry
Flight distance : 4726654 ft
Latvia
djiuser_leGPDcjqDZxa Posted at 6-18 19:05
"RTK base is transmitting in a local geoid"
The RTCM standard does not transmit anything in "geoid", unless you have set manualy the altitude of the base station in local height. Which is a mistake. To be sure, go to the settings, RTK tab and check the coordinates of the base. The altitude must be the ellipsoidal one.
The altitudes displayed on the mission planner in case of terrain follow are expressed in ASL (EGM96). For consistent terrain monitoring, it is therefore necessary to give it a raster in vertical EGM96 format.
2024-6-18
AR_AirPrecision
Flight distance : 2683589 ft
Belgium
I would recommend to change the lens to the 50mm, "too low/12m" is not only about altitude but also focus, overlap, speed, ... You could also check with another mission planning like UGCS.
2024-6-19
