christangey
Direct from DJI Support. I have heard rumours for a long time about being able to use adjustments crews to fix the slow speed issue (getting the M3 to fly as slow as the M2P)
on the M3, but personally I had never been able to track down how you actually go about it, until now.
I am still considering whether I will try this or not as it must have some inherent risk and DJI have indicated they are also working on a firmware solution for this anyway.
However I will put this out there for those who wish to try it, word for word from DJI (PS In trying to post this no matter what I do, by including the photo provided by DJI, the forum tells me the post is "oversize". So if you want the photo you can find it in the Mavicpilots forum or just email me via the Alice Springs Film and Television website, thanks!) :
"Like the DJI FPV remote controller, the control stick hand feel of the DJI RC Pro remote controller is adjustable. Details are as follow. However, you also know that our final plan to optimize the speed in Cine mode will still focus on providing speed adjustment options, that is, starting from the engine level. So in fact, the meaning of a single adjustment of the "accelerator pedal" may not be that big.
The screw size is H1.5 socket head cap screw
Right control stick:
F1 Right Stick Recentering Adjustment Screw (Vertical): Tighten the screw clockwise to increase the operation resistance in the upper and lower direction of the control stick at the corresponding side, and vice versa.
F2 Right Stick Recentering Adjustment Screw (Vertical): Tighten the screw clockwise to prevent the control stick from recentering in the upper and lower direction at the corresponding side, and vice versa.
Left control stick:
F1 Left Stick Recentering Adjustment Screw (Vertical): Tighten the screw clockwise to increase the operation resistance in the upper and lower direction of the control stick at the corresponding side, and vice versa.
F2 Left Stick Recentering Adjustment Screw (Vertical): Tighten the screw clockwise to prevent the control stick from recentering in the upper and lower direction at the corresponding side, and vice versa.
Note: F2 Right Stick Recentering Adjustment Screw (Vertical) and F1 Left Stick Recentering Adjustment Screw (Vertical) are in the customizable C1/C2 buttons. To adjust them, open the portion with printed letters on the C1/C2 button, and the screw holes can be seen inside."
