TAZ
To download your flight logs for more detailed inspection:
1). Connect your iPad to iTunes.
2). In iTunes, Select the Apps Section on your device.
3). On the right side of the iTunes screen scroll to the very bottom of the screen until you see the File Sharing section.
4). Select the DJI application
5). On the right side of this screen, you will see the DJI documents.
6). Drag and drop the FlightRecords folder onto your desktop. You only have the option to drag the entire folder...not specific Flight Records.
You will now have your flight records locally on your computer. They are not readable in this format, but you can convert them to a readable format:
1) Find the correct Flight Record text file on your desktop.
2) Go to djilogs.com
3) Upload the associated Flight Record Text file
Your can now convert this flight record to a readable format (Comprehensive CSV) and read it in Excel for example, or into a Google Earth format...or both. The Google Earth format will display your complete flight path in 3 dimensional space. If you don't have Google Earth, you can now download the PRO version for free: just use GEPFREE as the License Key.
In the CSV file you can look at the columns OSD.latitude and OSD.longitude last entry record...and that will tell you it's last known location. You can type those coordinates into iOS maps (with a comma between the two) or any GPS application, and you'll see precisely where it was. Loading the KLM file into Google Earth will help you identify the location in 3 dimensional space, and if you zoom down to a surface view, you'll be able to see sorounding landmarks.
