indoor flight
566 4 2022-8-18
djiuser_qiim4mZkIQGs
I want to take some pictures of our high school volleyball team.  what problems might I encounter when flying in they gym?
2022-8-18
DowntownRDB
Flight distance : 1722 ft
A few things to consider from a guide I followed:
- Do you have the high school principal's permission?
- What’s that area specifically like?  Is there going to be any sort of signal interference?
- How will the flight go? Where will you take off and land?
- As far as pre and post flight, where can you set up your gear?  Will you have a place to charge batteries?
- Where will the people be, and can you avoid flying directly over them?
- What is the lighting like?  Will you be looking into a fluorescent gym light?  Will there be dark, dramatic lighting, potentially blocking your view of the drone?
Keep in mind that even the most experienced pilots don’t conduct their first flight live at the event in most cases.  Especially since you won’t be able to use all the automatic flight modes given your indoor flight, you need to be comfortable in manual mode. Plus, doing a test run-through ahead of the event gives you a good sense of the best angles for the video you’ll be creating.
Have fun but fly safe.  Be a great representative for the drone community.
2022-8-18
Rustic17
Flight distance : 2702254 ft
Definitely have prop guards on...you don't want to hurt anyone if you can avoid it.  Understand you will probably not have GPS.  Be sure you make some practice flights with no one else in the gym.
2022-8-18
DJI Stephen
Super Moderator
Hello there. Good day and thank you for reaching out.  Just a friendly reminder that DJI do not recommend flying your DJI drones indoors as the environment indoors may have interference and caused an incident and also during low light condition as the vision sensors may not work properly. DJI suggest to choose an outdoor open area where the GPS is good, no magnetic interference, to fly your DJI drone and check if all the functions are normal. Thank you and fly safe always.
2022-8-18
djiuser_zyYUBx8zX7yE
Poland
I think It can be danger.
2022-8-21
