Poor Stitching in DJI 360 Pano Feature
1694 31 2022-8-21
Blériot53
Flight distance : 6337615 ft
All updates performed, gimbal checked for level horizon, ideal flying conditions (virtually no wind).
I was keen to try this function of the Mini3Pro - the one I was most looking forward to.
Three panoramas executed - all of which exhibit poor stitching in one or two areas.
After the first one, I thought it may have been just the vertical axis at the start/finish point, but there are horizontal
mismatches as well.
I'm wondering if it's a problem with the rate of movement of the drone between shots - there seems to be little time for the drone/gimbal
to settle before the next shot is taken.
2022-8-21
Bussty
Flight distance : 359705 ft
New Zealand
Mr B the internal stitcher seems quite variable, I never use it. Have you tried setting the output to RAW or jpegs then stitching them manually?  Invariably will give a better result. When you are spending $100-$200 on an external stitcher that's rock solid you know DJI isn't going to be incorporating that level of accuracy and adjustability in a drone that already has a lot to think about. If you have 35 jpegs or DNG's to package up send a Google Drive link and happy to see how it goes in PTGUI but I think you'll get an OK job from Microsoft ICE .  Having said that square buildings and tiled and corrugated iron rooves are tough for any stitcher...
2022-8-21
Blériot53
Bussty Posted at 8-21 04:26
Valid observations, Bussty, thanks.
At the default settings, the Mini3Pro just produces a finished article, and the individual images seem to be discarded. I shall have to set J-RAW to get the saved images in order to work on them externally.
I have Microsoft ICE and AutoPano Giga.
Next job will be to alter the settings in the drone and save the individual images to work on
2022-8-21
Bussty
New Zealand
Blériot53 Posted at 8-21 04:32
Tis the best path
2022-8-21
Blériot53
Bussty Posted at 8-21 12:14
Tis the best path
2022-8-21
DJI Stephen
Hello there Blériot53. I am sorry for the trouble this has caused and thank you for giving out these information. I hope that our fellow DJI co pilots can share what editing / stiching software they are using to create 360 Panoramic Photos. Thank you.
2022-8-21
Blériot53
DJI Stephen Posted at 8-21 21:14
DJI Stephen, may be your team could look again at these shortcomings to see if there is a solution, if the problem persists?
2022-8-21
Drone Jockey
I noticed stitching errors on cars too.
My next try will be using DNG images in Affinity Photo, which is my preferred photo editor and is also able to create all kinds of panos.
2022-8-21
Blériot53
Drone Jockey Posted at 8-21 22:42
I'll be going down that route too, I think. WHen it stops raining
2022-8-21
Mavic57pro2
Flight distance : 3943934 ft
Seriously bad stitching errors, DJI please look into this and provide a solution.
2022-8-25
Blériot53
Mavic57pro2 Posted at 8-25 14:11
Meantime, l'ii try to ignore the imperfections
2022-8-25
SPLflyer
Flight distance : 144829 ft
Blériot53 Posted at 8-25 22:57
As long as I still made my panoramas with the Mavic Air, my workflow was very elaborate and complicated. Because the version of PanoramaStudio at this time couldn't handle DNGs properly, the DNGs had to be first developed in Adobe Camera Raw, corrected for brightness and color, and finally transferred to Photoshop, where retouching (propeller shadows, etc.) was done. Saved as TIFFs, I then stitched them in PanoramaStudio, which was generally flawless. Afterwards, the finished rectangular image was manually given a realistic sky in Photoshop. This was done via content aware filling in both 2D and 3D modes. Finally, the whole image was finally refined in Photoshop and plug-ins.
Thanks to the new firmware of the Mini 3, the process has become much easier. The DNGs can now be read and developed directly into PanoramaStudio and stitched without errors. The sky is also finished – except for a small strip. Finally, the TIFF goes straight to Photoshop for qualitative fine-tuning and for the missing part of the sky. Done!
Dear Blériot, you have invested 1000 $ for the Mini 3. Invest another $80 for the latest PanoramaStudio 3 Pro version, and ~ $60 for Affinity Photo. Then you have the complete tools for first class panoramas in the fastest way. PS3P does the DNG development and stitching, Affinity Photo solves spherical correction problems with its excellent 3D processing and does the qualitative finishing. Plus, with PanoramaStudio, after importing the finished pano back, you still have the option of exporting your pano to HTML5 ready to run.
This panorama has a similar motif to the one you showed above. It was created using my new, fast workflow and is absolutely error-free.
Think about it!
(...and sorry for my poor school english ;-))
2022-8-26
Blériot53
SPLflyer Posted at 8-26 00:34
It does look rather splendid.  You make a good case for the software
I may see what the kids are prepared to spend on their dad ( I have a birthday coming up
(Und Ihr Englisch ist viel besser als mein Deutsch)
2022-8-26
bxq
Flight distance : 3139314 ft
Poland
Honestly i do not get why all the stitching or assembling hyperlapse is made on the drone mid flight blocking all other actions during this.
IMHO should be an option to do it after landing on connected PC/MAC.
2022-8-26
Blériot53
bxq Posted at 8-26 03:48
It might help. yes.
2022-8-26
PeterIOM
Flight distance : 813419 ft
Isle of Man
Has anyone had any luck stitching these 360 Panos in Adobe Lightroom?
2022-8-26
Blériot53
PeterIOM Posted at 8-26 07:24
Not me, sorry.
2022-8-26
AVsupport
Flight distance : 618734 ft
Affinity and PTGui Pro are seamline aware plus can manage HDR, exposure fusion and masking. Worth investing IMO.
Doesn't fix the DNG vignetting issue currently still present however, I do that with a custom LCC in CaptureOnePro.
2022-8-27
Blériot53
AVsupport Posted at 8-27 22:36
We're getting into the realms of Too Complicated for my casual interest
And my limited brain power
2022-8-27
Montfrooij
Flight distance : 2560453 ft
Yes, I noticed this too!
2022-8-30
Blériot53
Montfrooij Posted at 8-30 00:53
It's a disappointment - but only if you look too closely
2022-8-30
Montfrooij
Blériot53 Posted at 8-30 01:02
How did autopano do?
2022-8-30
Blériot53
Montfrooij Posted at 8-30 01:04
It does a better job of the stitching, from the DNG files, but the colours are washed out and I have to bring them back up with software.
2022-8-30
Montfrooij
Blériot53 Posted at 8-30 01:21
I never use DNG TBH.
Requires too much post processing (AEB has that too, but still less)
2022-8-30
Blériot53
Montfrooij Posted at 8-30 01:36
Thing is, the MINI3Pro doesn't store the individual frames if you shoot 360 in JPEG. It composits them in flight and just presents you with the finished Pano.
2022-8-30
Montfrooij
Blériot53 Posted at 8-30 02:28
Oh ok. Weird.
2022-8-30
Blériot53
It is rather.
2022-8-30
SPLflyer
For good results, there is only the hard way (which you can walk on various side paths).
I often spent several hours working on my Mavic Air panos, although much of which were spent creating the missing sky.
2022-8-30
Montfrooij
I hope they will fix that.
2022-8-30
Blériot53
SPLflyer Posted at 8-30 03:28
I figured out the skyfill using Layers in Autopano Giga.
2022-8-30
Blériot53
Montfrooij Posted at 8-30 03:55
Here's hoping
2022-8-30
Montfrooij
Cheers to hoping!
2022-8-30
