Ronin 4D IMU Error
2353 17 2022-8-21
glennsparklevfx.com
Flight distance : 636598 ft
Hello,
I've been using the Ronin 4D for a while now, just today an error message popped up. 'IMU Error. Contact Support
Is there an IMU calibration or will I have to send the unit back?
As luck would have it, I'm on a shoot with it Tuesday (it's Sunday night now).
Any advice would be appreciated
Thanks
Glenn
2022-8-21
C Irion
I have exactly the same problem. I see that this issue was posted more than a month ago. Could someone from DJI please give us some professional support?
2022-9-23
glennsparklevfx.com
C Irion Posted at 9-23 09:09
Hi, it happened a lot less since the recent update but I can't get to the root of why it's happening. Doesn't seem to effect using it too much
2022-9-23
Eponym
Not 100% certain if this applies to the 4D, but I would get the IMU error all the time if I booted up my drones near magnetic/metal areas or booting it up while holding it in my hands. Are you turning on the 4D away from metal surfaces and resting the body when powering on?
2022-9-23
DJI Thor
Flight distance : 13602 ft
Hi, there. We are greatly sorry to hear about that. Please follow the instruction below and keep us updated, we will make further checks with our team:
1. Please tell us the Lens model
2. Please try to calibrate the Z-Axis.
3. Try to change to other environments in case it is caused by strong electromagnetic interference.
2022-9-23
DJI Thor
Hi, there. Sorry for your inconvenience. Please try to follow the steps provided on #5 to see if it works. Thank you.
2022-9-23
glennsparklevfx.com
DJI Thor Posted at 2022-9-23 20:22
Hi. Using 35mm and 50mm DJI DL lens. Happens in all environments, indoors and out door. Thanks Glenn
2023-11-15
djiuser_LnDSBdVDRVok
Malaysia
Sorry to crash this thread. Why cant a newbie start a thread/ ask a question ?
2023-11-15
DJI Thor
glennsparklevfx.com Posted at 11-15 15:02
If the issue still persists, would you please provide the following details? We will further check with our engineer team.
1. Product serial number.
2. Please provide a Balance adjustment display (including the balance adjustment display on the high-bright main monitor).
3. Please provide a display after auto tune.
2023-11-16
DJI Thor
djiuser_LnDSBdVDRVok Posted at 11-15 21:43
Hi there, for more details about the Forum Rules and Regulations, you could please read the comment 16# & 17# via the following link, thanks.
https://forum.dji.com/forum.php? ... mp;page=1#pid623200
2023-11-16
glennsparklevfx.com
Hi. Images attached, let me know if you require any further information. Thanks Glenn
2023-11-16
glennsparklevfx.com
HI, Was this the correct information you required?
Glenn
2023-11-25
glenn
Hi,
I wonder if you can help me. I resolved the IMU problem, i returned it to DJI in the Netherlands. They sent me back a different unit than the one I sent. The unit I received had more issues than the unit i sent to be repaired, ive now sent this unit back and they have sent me a bill for the repairs. I don't believe i should pay this as the unit i they sent to replace my original unit had these issues when they sent it out.
Any help would be appreciated
CAS-15961451-F4Y9J8
Glenn
3-28 01:49
DJI Thor
glenn@sparklevfx.com Posted at 3-28 01:49
Hi,
Hello Glenn! Thank you for getting in touch with us. Please don't worry as we will assist you in checking with our service center first.
Meanwhile, could you please let us know the issues you are facing with the replacement device? This will help us deliver the message more accurately to our service center. Thank you.
3-28 01:56
glenn
DJI Thor Posted at 3-28 01:56
The unit i sent back and is currently with them has issues with he Fan, ND filters, and Z Gimbal. All these issues where present when i go the camera back
3-28 02:08
DJI Thor
glenn@sparklevfx.com Posted at 3-28 02:08
Hi there, we could like to follow up on your concern about your inqiury. Our team has investigated and found that the Z Axis IMU Board has been replaced with a new one that is not defective in one of your previous case CAS-******-J3N4G3. However, we also discovered that in the case of CAS-******-F4Y9J8, the Z Axis IMU Board was unable to fold completely and the cooling fan was making an abnormal sound. We replaced both of these items under warranty, so there were no repair charges. Unfortunately, the ND Filter Control Board is no longer under warranty, so we are unable to replace it for free. We have included the replacement cost in the quotation, and once the payment is complete, our team will conduct a quality test on the replacement items. Let us know if you have any further questions!
3-28 19:54
glenn
DJI Thor Posted at 3-28 19:54
Hi,
Thanks for getting back to me. The point I think everyone is missing here is that the second camera i sent back for repair was not my original camera. This Unit had these defects on upon my receiving the unit. If you check the serial numbers of my original camera and what was returned to me, it was two different units. This means I’m paying for defects that never belonged to me.
I not sure i understand your offer, is that £30 discount or £30 overall to pay?
PLease advise.
Thanks
Glenn
3-30 06:19
DJI Thor
glenn@sparklevfx.com Posted at 3-30 06:19
Hi,
Thank you for your reply. We will forward to our relevant team and further check with them. We will update you by e-mail, please kindly keep an eye on it, thanks.
4-1 22:36
