error 30252
1948 4 2022-8-22
riwer
Flight distance : 54938 ft
Russia
Hi,
I just got a brand new air 2s and when i try to take off first all the motors spin up but after a moment i get an error
"Check whether propellers are installed correctly. If the propellers are installed correctly and the aircraft still cannot takeoff, a motor error may exist. Contact DJI Support for assistance (Code: 30252)"
The application displays a picture with the top right propeller highlighted (not sure if that matters).
In fact, all propellers are installed correctly (propellers with marks are installed on motors with marks).
2022-8-22
fateofangel
Flight distance : 1397238 ft
Poland
you have to contact support, but please dismount and install propellers again to make sure
2022-8-22
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble that this has caused. May I please ask if you have a spare or extra set of propellers and please try those to see if the issue persists? You may refer to the tutorial link below on how to properly install the propellers please start at @0:40 on the video. Please keep us posted. Thank you.
2022-8-22
djiuser_AXRRyEWz3HHD
Bulgaria
Hi there! I had the same problem, but with DJI Mini 3 Pro. I also check the propellers, they were ok. While searching how to fix it, I saw this forum.
I have a decision of this problem. Just calibrate the drone. It worked for me! I hope it will work for you!
1-17 12:26
Shawgod
Flight distance : 5173104 ft
I ran across this problem and I just calibrated the drone using the computer.
1-20 08:04
