Micro SD not recognized in Mini 3 Pro
23062 36 2022-8-22
phivestardave
Flight distance : 14281 ft
Hello everyone, I just purchased the Mini 3 Pro and it will not recognized that I have inserted a Micro SD card. I put it in (correctly, gold strips up) and it still says there's nothing inserted in the settings. However, if I insert the same SD card into the controller, it shows up in it's settings. I have tried reformatting it and it hasn't helped. Is it possible that the drone requires a higher tier card than the remote itself? What am I doing wrong? Thanks.
2022-8-22
Geebax
What make of card is it? Can you post a photo of it?
2022-8-22
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please confirm what specific SD card are you using? In addition, please try the suggestion of Dirty Bird on post #3 and check if the issue persists. Please keep us posted. Thank you.
2022-8-22
Beta5K
Flight distance : 196880 ft
Hopefully its not the card reader on the drone itself. Have you tried other cards to rule that out?
2022-8-23
fateofangel
Flight distance : 1397238 ft
Poland
unoriginal purchase or too slow
2022-8-23
Indio
Flight distance : 303373 ft
Austria
from the manual
2022-8-23
Drone Jockey
I once had a similar problem with a SanDisk Extreme Pro, that I unsafely ejected on my iMac before. It was no longer recognized by both the Mini 3 and the iMac and I had to do a rescue (re-partition) and reformat.
Since then the card works fine again.
So ... is your card recognized in other devices?
2022-8-24
phivestardave
I’ve included a picture of my latest SD card. I’ve tried 3 different ones… same result. It doesn’t recognize that there is a card in the drone. As I mentioned before, it works in the remote. I’ve tried the method mentioned above about inserting it in and out a few times, didn’t work. Should I format it in my pc somehow?
2022-8-24
SpectreOne
Flight distance : 79659 ft
phivestardave Posted at 8-24 12:08
The SDCard is the right type. I would try reformatting it in your computer and see if that refreshes it. You may have removed it from some device and caused the storage to corrupt.
2022-8-24
SwaroopK
Flight distance : 7526 ft
India
Even i am facing the same issue. Tried everything but still the same issue. I first experienced the same problem when I bought it, but I subsequently discovered that the issue had been solved after a sequence of device powers-on. I turned on the aircraft first, then the RC controller. Now, though, it is not detecting even though I use the same sequence of  power-on procedure. Did anyone was able to fix this ??
2022-9-30
fanse79cb5be
Same Card SanDisk Extreme 128 GB........Same Problem
2022-10-14
Indio
Austria
most of the cheap sandisk cards are fake!
buy from a trusted dealer
2022-10-14
djiuser_neEwqWvx3Uxp
Flight distance : 735430 ft
Same issue.  I have used these cards with the Mavic 2 with no problems and with the Mini 3 Pro.   This was my 1st time using the DJI RC and a few strange things happened. The card filled up really quickly and now it's unreadable by both the drone and my computer.  I probably should have formatted it 1st as there were other items on it.
Also not GPS when the RC was connected to my phone hotspot.  No directional info at all on the RC.
2022-10-16
Same issue.  I have used these cards with the Mavic 2 with no problems and with the Mini 3 Pro.   This was my 1st time using the DJI RC and a few strange things happened. The card filled up really quickly and now it's unreadable by both the drone and my computer.  I probably should have formatted it 1st as there were other items on it.  Any idea how to recover the data?  The same card that's posted.
2022-10-16
Mat2022
Flight distance : 391532 ft
Ho avuto lo stesso problema , cambiando la SD ho risolto. Credo che in giro ci siano delle SD Fake , quelle comprate su Amazon mi funzionano tutte .
2022-10-27
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
Maybe the memory card is not fully inserted?
I use: Kingston Canvas Go Plus 64Gb V30 A2
2022-10-27
djiuser_d7eZhxUi7mal
Flight distance : 125 ft
Same issue, same card, new, From Argos
2022-12-3
phivestardave
I wanted to come and update you guys or anyone else who stumbles across this thread. I tried several different SD cards and tried formatting numerous times. Nothing worked. I carried the drone back and got a replacement. The SD card worked perfectly in the replacement drone. I evidently had a faulty reader. If you have this issue, return and replace if that is an option for you.
2022-12-4
phivestardave Posted at 12-4 11:42
Oh really! That's not good!
2022-12-5
djiuser_tX6b0RhMBXde
Saudi Arabia
I’ve included a picture of my latest SD card. I’ve tried 3 different ones… same result. It doesn’t recognize that there is a card in the drone. As I mentioned before, it works in the remote. I’ve tried the method mentioned above about inserting it in and out a few times, didn’t work. Should I format it in my pc somehow?[Image]
Dear
I found some people are confused between the SD card slot in the controller and the aircraft. Make sure the memory in the aircraft slot after proper formatting.
Regards
2022-12-7
Saudi Arabia
Dear
Regards
2022-12-7
djiuser_FAQ1QIKWa4Pi
I’m having the same problem. I am using the Samsung 512 pro plus.
2023-4-14
DJI Natalia
djiuser_FAQ1QIKWa4Pi Posted at 4-14 11:27
Hi, there. Could you please try to use a support SD card for Mini 3 Pro and see if your problem can be resolved? You can check the below photo to get more info:
2023-4-14
jgrieves1gmail.com
I was struggling to get the sd card to stay in. Kept popping back out.
I have just read on youtube ....'take the battery out first'  So....battery out, long fingernail, push deep and voilà! Worked for me.
How you get it out is another matter.
2023-4-16
djiuser_6O5lCWLJQeKu
IMPORTANT NOTE
THE MICRO SD NEED TO BE IN THE DRONE NOT IN THE CONTROLLER.
2023-5-15
djiuser_J5TMY80BYKhv
Flight distance : 866778 ft
djiuser_6O5lCWLJQeKu Posted at 5-15 06:47
IMPORTANT NOTE
Thank you! God Bless you!!!!
2023-5-27
djiuser_QrkA79BiFggN
I just found this forum but I am literally having the same issues. My drone has been to dji and they state nothing is wrong with it. It will not accept any recommended sd cards only one sd card that’s not even recommended a Sandisk 4gb is what it will actually run. I have multiple Sandisk extreme and ultra cards and it will not read any of them. I have tried to format all of them on a pc and have had no luck.
2023-6-30
Tjtolley
Same issue here… new drone, new SIM card full of pics/vids. I plug the card into the controller and nothing comes up. Anyone have a solution? Frustrating…
2023-7-2
DJI Paladin
Tjtolley Posted at 7-2 05:32
Hi there.  We do apologize for the inconvenience. After inserting the SD card into the DJI RC, slide down the screen and click on the SD Card prompt on the left to enter:
If there is no SD card prompt popping up on the left side of the screen or if you close the SD card prompt, you may enter through the following path:
Slide down the screen - settings - storage - internal shared storage - music and audio - audio files - select the SD card on the upper left to display the files on the SD card.
2023-7-9
Jan_FR_NL
Same issue, same 128 GB (fake ??) card.
My solution: put the card in the controller, switch on the controller, see if the card is working , maybe you have to format it in the controller from the menu (pull down from the top of the screen) but in my case the card was working allready.
Stop controller, remove the card from the controller and put it in the drone, remove the battery from the drone and slide it back in, start the drone, the drone will detect that there is a card inserted and recognize it. Start the controller and you will see there is about 3 Hours of estimated storage space available.  Click on this time indicator and you will see the GB details.
2023-7-16
orpheeokito
Thought I I had the same issue but everything was fine! INSERT CARD INTO THE DRONE...NOT in the controller!!
2023-8-17
dj-b
Northern Mariana Islands
I had the same problem not being able to read my microSD card from the Mini 3 in my computer. I am on an M2 Mac.  When I would plug in my reader, something would briefly flash on the screen but I was unable to read it.
Solution: Under Privacy & Security I found a setting asking "Allow accessories to connect?"   I set it to Allow always when unlocked.   That solved it.
2023-8-28
Ken Palmer
You do have to format the SD cards in the drone and the handset
2023-9-18
djiuser_GfK2sjfmXSnG
I have had the same issue with my DJI mini 3 but I used a micro sd disk that was old so I did some reasurch and found that it only supports disks that are a Sutton class or higher. I hope I was able to help
2023-12-26
djiuser_elY2LBq36hDD
Flight distance : 85748 ft
I bought a pair of Samsung EVO card and they works very well in all the devices
2023-12-30
Garry Fancy
I have same problem with mini 3, controller, tried everything. Any suggestions?
1-16 04:05
DJI Gamora
Garry Fancy Posted at 1-16 04:05
Hi, there. Thank you for your reaching out. May I confirm the exact model of the SD card and if you tested a different one? For SD Card recommendations, you may refer to the image below. I hope to hear from you soon.
1-19 02:36
