busclas
Flight distance : 609012 ft
o there is this file floating arounf the internet that supposedly gives you back all 32 custom channels. Ill admit i was intrigued as i came along after the firmware update removed them.
History
200000 feet of flight
Just over 10 hours
96 + flights
1.3 makes my second firmware upgrade
Still using first set of qr props
Only issue was a compass error once taking off in a questionable location
No crashes bumps shakes ever.
Issue
Just upgraded firmware, was running all my batteries down to 5% did not calibrate imu, but was prepared for those issues, as all three flights were in an open field and i was staying below the tree lines. I had installed this file mentioned above and could see all 32 channels but they showed no signal so alresdy planned to remove it. Halfway through the second battery, i get the error in the image. I cant say for sure if it was the 1.3 firmware, no imu calibration or the file i installed. Long story short, stay away from this file, i cant see it makes a difference and now i will have to build my confidence back up before i go back to trusting my craft like i did before. As someone else in another forum pointed out, theres no legit way to tell if it contains a virus with some malicious intent or some poorly coded jargon that could cause you to lose your craft. |
