MAYKITHRT
Flight distance : 219167 ft
Hi.
For all those with the connection issue with the Avata to the flight simulator and receiving that "connecting circle" or/and the blue writing saying to connect to the Goggles 2 and you're not getting anywhere, I've discovered a solution. I was receiving the same headaches, reading the forums, and agreeing in frustration especially when I used it with the FPV and everything worked perfectly. My setup was similar to most yours e.g. connecting to your iphone to the goggles 2 then the controller then BAMM! Nothing. But everything worked once I changed the regular iphone charger cable to one that does a fast charge. It's a thicker cable and carries, I guess, more data faster. Whatever the case, it worked. I tried it on both my ipad pro and iphone XR. And if you've got the more recent phones, it definitely should work. Another thing is that when you get the "connecting message with the circle" tap the blue writing in the middle of screen about "connecting to the goggles 2". Once you do that go to your goggles>settings>virtual app and select it. Afterwards, you iphone/ipad simulator screens and the goggles should all reflect the same screen. Now you're good to go. Get to flying and leveling up. I'm typing a lot of this from memory so there might be some minor adjustments but you've got the point. Good luck! |
