Brand new Mini 2 battery not charging but blinking
9154 16 2022-8-26
tharaka_rehan
Sri Lanka
Hi all. I purchased a DJI Mini 2 Fly More Combo today. First, as mentioned in the user manual I was trying to charge the battery (which was inside the drone) by connecting the drone to USB charger (which came with the combo). For the first 10 seconds, the LEDs were indicating the charging status. After that however the LED 3 and 4 in the drone blinked simultaneously three times and was repeating that pattern. The battery did not seem to be charging. Then I tried to charge it with two way charging hub, but could encounter the similar blinking pattern as in the drone. The other two batteries which came with the combo works fine. What seems to be the problem? According to the user manual this happens when the battery is not inserted properly. But the battery clicks nicely. I have attached two videos of that battery charging in drone and in two way charging hub.
2022-8-26
SpectreOne
Flight distance : 79659 ft
Seems like something is wrong with your battery. Do you have another battery to see if the problem is present with that battery as well inside the drone? Have you tried cleaning the contacts on the battery to rule out any dirt or corrosion? Its possible that the contacts are dirty which is preventing a good connection when trying to charge.
2022-8-26
tharaka_rehan
Sri Lanka
SpectreOne Posted at 8-26 12:54
The other two batteries are charging fine in both drone and the hub. I have not tried to clean the contacts on the battery. Thank you for the suggestion. Anyway trying to clean contacts will that affect the warranty?
2022-8-26
DJI Stephen
Hello there tharaka_rehan. I am sorry for the trouble this has caused and thank you for reaching out. Since we are having this issue with one of your DJI Mini 2's intelligent flight battery. I would recommend for your to contact our DJI Support Team at https://www.dji.com/support?site=brandsite&from=nav for further assistance. We will do our best to help you and give out the best resolution for this issue. Again, I am sorry and thank you.
2022-8-26
tharaka_rehan
Sri Lanka
DJI Stephen Posted at 8-26 19:52
Hello. I will contact the support team. Thank you.
2022-8-27
DJI Stephen
tharaka_rehan Posted at 8-27 10:26
Hi there tharaka_rehan. Thank you for the reply and for this update. If you have any other concerns or any issues in the future with DJI. Please feel free to post it here at DJI Forum. We are all here to help and assist you. Thank you.
2022-8-27
HUNkisvex
Flight distance : 2088219 ft
Hungary
Hey! I'm having the same issue with one of my batteries, I'm curious if you could solve it by yourself or did you sent it back to DJI?
2023-4-6
djiuser_CO11doziJFQh
Flight distance : 135236 ft
Bosnia and Herzegovina
hi everyone, i have the same problem. can someone help me ?
2023-4-29
Shawgod
Flight distance : 5173104 ft
How many charge cycles do you have on the battery?
2023-4-29
None, brand new
2023-4-29
Richard Borst
I have the same problem. I think the battery is defect, but not sure
2023-4-29
I put battery in drone and charged the battery for 2-3h and then everything was ok
2023-5-1
CrashTestr
I had the same problem and was able to fix it by changing the charging box. I was using the Belkin USB-C box (which works to charge the battery in the drone), and I switched to a Samsung USB fast-charging box, and now it works great!
2023-7-2
djiuser_8Nvd7NSzxbfj
Richard Borst Posted at 4-29 23:24
Was the 2 lights  flashing the whole time on charger ? Untill charged ?I just got brand new mini 2 se doing same thing
2023-12-30
2023-12-30
DJI Tony
djiuser_8Nvd7NSzxbfj Posted at 12-30 17:11
Hi there. Sorry about the trouble. Is your battery not charging? Have you already tried leaving it charging for about 2 hours? Thank you.
2023-12-30
cyan
Ban Posts
Flight distance : 202326 ft
1-6 22:20
